{"product_id":"aim-mxs-strada-light-5-tft-car-dash-display-with-road-icons","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXS 1.3 Strada Light 5\" Display TFT per cruscotto auto con icone stradali","description":"\u003cdiv id=\"shopify-section-template--17924582113382__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDisplay del cruscotto compatto\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eL'MXS Strada con icone stradali è uno dei display per cruscotto più utilizzati sulle strade di tutto il mondo. La versione Strada \u0026quot;Light\u0026quot; è stata creata per offrire un prodotto più accessibile a chi utilizza meno ingressi analogici e necessita solo di una connessione CAN per la propria centralina.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924582113382__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePerché scegliere il display luminoso MXS 1.3 Strada\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePur essendo molto simile all'MXS Strada, l'MXS Strada Light offre 4 ingressi analogici completamente configurabili (max 500 Hz ciascuno) invece degli 8 presenti sull'MXS Strada standard (max 1.000 Hz ciascuno). Inoltre, non dispone di un'uscita digitale o di una connessione RPM, presenti invece nell'MXS Strada standard.\u003c\/p\u003e  \u003cp\u003eScegliere OBDII o K-Line CAN, a seconda che si desideri connettersi alla ECU del veicolo o alla porta OBDII oppure direttamente alla ECU tramite il canale CAN.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924582113382__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eConnessione facile\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCollegare il cruscotto MXS 1.3 Strada Light alla centralina è semplice. È possibile campionare e visualizzare decine di canali direttamente dalla centralina del veicolo. Questa è solitamente la configurazione più rapida e semplice, poiché richiede solo 2 cavi di collegamento alla centralina anziché molteplici collegamenti ai sensori analogici.\u003c\/p\u003e  \u003cp\u003eI dati campionati dipendono dalla centralina elettronica effettiva, ma in genere includono giri\/min, posizione dell'acceleratore (TPS), temperatura dell'olio, dell'aria e dell'acqua, pressione dell'olio, tensione della batteria, velocità, marcia e valore lambda (rapporto aria\/carburante). L'elenco dei driver ECU disponibili è di oltre 1.000 e viene costantemente aggiornato e potenziato.\u003c\/p\u003e  \u003cp\u003eCon l'uscita CAN, è possibile inviare messaggi direttamente a una rete CAN esistente per migliorare la gamma di possibilità di controllo del veicolo. Sono inoltre disponibili due ingressi per telecamera analogica per trasformare il display in un\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003etelecamera a specchio\u003c\/a\u003e, tramite comando a pulsante o gestione eventi. La telecamera è venduta separatamente.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924582113382__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay con icone stradali\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLa MXS 1.3 Strada Light ha un design compatto 5\" Display TFT a colori ad alto contrasto. La qualità visiva è ottimizzata dal sensore di luce ambientale, che mantiene la retroilluminazione ai livelli di luminosità ottimali.\u003c\/p\u003e  \u003cp\u003eLe icone stradali consentono di applicare condizioni alle icone LED, come carburante, motore, olio, luci, indicazioni e altro ancora.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924582113382__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePagine preconfigurate\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eL'MXS 1.3 Strada Light mostra la scala RPM e tutti i dati necessari, come velocità, temperatura dell'acqua e pressione dell'olio, tempi sul giro e molto altro. Puoi personalizzare le pagine in base alle tue esigenze, includendo fino a quattro campi aggiuntivi, e puoi definire quali dati visualizzare con il fondo scala e le unità di misura.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924582113382__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eLuce di cambio flessibile \u0026amp; Allarmi\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eLe 10 luci di cambio marcia RGB multicolore possono essere personalizzate a proprio piacimento, definendo la soglia di giri su ingressi analogici o digitali, valori della centralina, valori di espansione, canali matematici o opzione GPS opzionale. È possibile scegliere le condizioni e i colori, selezionare un braccio fisso o lampeggiante e anche la frequenza di lampeggio. È inoltre possibile configurare un messaggio di testo di accompagnamento e impostare le priorità di allarme.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch2\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h2\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":40138061381734,"sku":"MXS-S-I-L","price":885.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_MXSSTRADALIGHTROAD_00.webp?v=1770643766","url":"https:\/\/www.aimshop.com\/it\/products\/display-cruscotto-auto-aim-mxs-strada-light-5-tft-con-icone-stradali","provider":"AimShop.com","version":"1.0","type":"link"}
