1 di 4
K series keypads OPEN - K6 / K8 / K15
SKU: k6-O
Prezzo regolare
£185.00
Prezzo regolare
Prezzo di vendita
£185.00
K6/K8/K15
The CAN-Bus Keypads Series OPEN
Compact, Fully customizable, water and dust proof
The K6, K8 and K15, just like GPS09 or ACC 2, are available in "Open Version". These keypads can be easily configurable via USB with Aim software RaceStudio 3 for transmitting the data via CAN to every external device. The devices are water and dust resistant and can be installed both inside and outside the cockpit. They are fully customisable and proposed with a wide range of interchangeable inserts.
The "Open Version" can also be used as an Aim Expansion, without any issues or limitations.
The keypads will enable you to have your very own selected buttons at your fingertips. Available in 6, 8 and 15 key keypads.
Reconfigurable buttons Programmable RGB LEDs
LED backlit rings and icons Momentary, toggle and multi-status
2 blinking mode Wide range of inserts
CAN-Bus system compatible Vertical or horizontal mount
Status restore option
The Push buttons can be:
MOMENTARY
  • The pushbutton status is ON when the pushbutton is pushed.
TOGGLE
  • The pushbutton status changes from ON to OFF every time the pushbutton is pushed.
MULTI-STATUS
  • The pushbutton value changes from 0 to a MAX value every time the pushbutton is pushed.
RGB LED's
RGB LEDs are the best choice in low visibility conditions. Every pushbutton can be enlightened in 1 of 8 different colors, solid or blinking, according to the configuration defined by the user.
  • K6 PushButtons: 6 programmable Keys
  • K8 PushButtons: 8 programmable Keys
  • K15 PushButtons: 15 programmable Keys
  • Backlight: RGB with dimming option
  • Connection: USB CAN 7 pins Binder 712
  • K6 Dimensions: 97.4 x 71.4 x 24 mm
  • K8 Dimensions: 127.4 x 71.4 x 24 mm
  • K15 Dimensions: 157.4 x 71.4 x 24 mm
  • K6 Weight: 120g
  • K8 Weight: 150g
  • K15 Weight: 250g
  • Waterproof: IP67
Remote Button CAN Interface Pro Keypad
  • Your choice of Aim CAN Open Expansion Keypad
  • Your choice length for the Unterminaited CAN Cable
  • USB & Ext Power Cable For Aim Open CAN Keypad
K6/K8/K15
MOMENTARY
TOGGLE
MULTI-STATUS
RGB LED's
Technical Specifications
  • K6 Weight: 120g
  • K8 Weight: 150g
  • K15 Weight: 250g
  • Waterproof: IP67
Whats in The Box
