{"product_id":"link-nissan-s15link-ns15x-plugin-ecu","title":"Link Nissan S15Link - #NS15X PlugIn ECU","description":"\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink Nissan S15Link - #NS15X PlugIn ECU\u003c\/h3\u003e\n\u003cp\u003eEasy to install. Affordable. Reliable. \u003cbr\u003e\u003cbr\u003eG4X PlugIn ECUs offer the latest in engine management technology, designed to easily maximize the potential of your car. \u003cbr\u003eThis ECU fits inside the factory OEM enclosure. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below. \u003cbr\u003e\u003cbr\u003eDesigned for the SR20 engine. This ECU will work with the 64 pins, blue header plug ECU version. \u003cbr\u003e\u003cbr\u003ePlease check your connector matches the header in the listed photo before purchasing. \u003cbr\u003eThis ECU works for manual transmissions only. \u003cbr\u003eECU includes an onboard 4 bar MAP or 7 bar MAP sensor. \u003cbr\u003eMost factory features are supported. \u003cbr\u003e\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eSuitable Applications:\u003c\/h3\u003e\n\u003cp\u003eS13 Silvia \/ 180SX SR20DET (but not CA18DET) \u003cbr\u003eS14a Silvia (facelift) SR20DET \u003cbr\u003eS15 Silvia SR20DET \u003cbr\u003eS15 Silvia SR20DE \u003cbr\u003eRNN14 Pulsar GTI-R SR20DET \u003cbr\u003eN15 Pulsar SR16VE \u003cbr\u003eN14 Distributed \u003cbr\u003e*For the 76 pin header ECU, have a look at the S13X PlugIn listing.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eG4X PlugIn Key Features (where applicable):\u003c\/h3\u003e\n\u003cp\u003eUp to 6D fuel and ignition mapping\u003cbr\u003ePrecision closed loop cam control (four cams, independent control)\u003cbr\u003eSequential fuel delivery\u003cbr\u003eDigital triggering, all OEM patterns\u003cbr\u003eOEM idle hardware supported\u003cbr\u003e5D boost control with three switchable tables\u003cbr\u003eMotorsport features - anti-lag, launch, flat shift\u003cbr\u003eContinuous barometric correction (onboard)\u003cbr\u003eCAN port\u003cbr\u003eQuickTime - automated fuel tuning\u003cbr\u003eIndividual cylinder correction\u003cbr\u003eUSB tuning cable included\u003cbr\u003eStats recording into on-board memory\u003cbr\u003eGear compensations for spark, boost and fuel\u003cbr\u003eReal-time selectable dual fuel, ignition and boost maps\u003cbr\u003eSync and crank sensors can be a combination of Hall effect, variable reluctance or optical\u003cbr\u003eBoost control referenced to gear, speed or throttle position\u003cbr\u003e512 megabytes data logging memory\u003cbr\u003eStaged injection\u003cbr\u003eKnock with \"windowing\"\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eI\/O Expansion Options:\u003c\/h3\u003e\n\u003cp\u003eThe following expansion connector inputs\/outputs are provided: \u003cbr\u003e\u003cstrong\u003eExpansion connector 1 \u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eGnd Sensor Ground Only \u003cbr\u003e+5V Out Low Current +5V Supply \u003cbr\u003eDI6 Digital Input \u003cbr\u003eDI7 Digital Input \u003cbr\u003eAn Volt 5 Analog 0-5V input \u003cbr\u003eAn Volt 6 Analog 0-5V input \u003cbr\u003eAn Temp 3 Temperature sensor input \u003cbr\u003eAn Temp 4 Temperature sensor input\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eExpansion connector 2 \u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eIgn 5 Ignition 5 Auxiliary output \u003cbr\u003eIgn 6 Ignition 6 Auxiliary output \u003cbr\u003eIgn 7 Ignition 7 Auxiliary output \u003cbr\u003eDI 8 Digital Input \u003cbr\u003eVolt 8 Analog 0-5V input \u003cbr\u003eVolt 9 Analog 0-5V input \u003cbr\u003eVolt 10 Analog 0-5V input \u003cbr\u003eVolt 11 Analog 0-5V input \u003c\/span\u003e\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch5\u003eWhat's in The Box\u003cbr\u003e\n\u003c\/h5\u003e\n\u003ch3\u003eLink Nissan S15Link - #NS15X PlugIn ECU\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eG4X PlugIn ECU\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWiring and Installation Instructions\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eStickers\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003cbr\u003e\n\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39270863634534,"sku":"NS15X","price":1475.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/LinkNissanS15Link-_NS15XPlugInECU.png?v=1616161643","url":"https:\/\/www.aimshop.com\/it\/products\/link-nissan-s15link-ns15x-plugin-ecu","provider":"AimShop.com","version":"1.0","type":"link"}
