{"product_id":"link-toyota-mr2link-v1-tst185x-plugin-ecu","title":"Link Toyota MR2Link V1 - TST185X PlugIn ECU","description":"\u003cp\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink Toyota MR2Link V1 - TST185X PlugIn ECU\u003c\/h3\u003e\n\u003cp\u003eEasy to install. Affordable. Reliable. \u003cbr\u003e\u003cbr\u003eG4X PlugIn ECUs offer the latest in engine management technology, designed to easily maximize the potential of your car. \u003cbr\u003eThis ECU fits inside the factory OEM enclosure. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below. \u003cbr\u003e\u003cbr\u003eDesigned for the 3SGTE engine in the models specified below. \u003cbr\u003e\u003cbr\u003eThis ECU works for manual transmissions only. \u003cbr\u003eA Link Air Temp Sensor is highly recommended with this ECU \u003cbr\u003eMost factory features are supported. \u003cbr\u003e\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eSuitable Applications:\u003c\/h3\u003e\n\u003cp\u003eToyota MR2 (SW20) from 1989 to 1992 \u003cbr\u003eToyota Celica ST185 (except the GT-Four RC\/Carlos Sainz Special Edition which is compatible with the Link TST205X Plugin)\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eG4X PlugIn Key Features (where applicable):\u003c\/h3\u003e\n\u003cp\u003eUp to 6D fuel and ignition mapping\u003cbr\u003ePrecision closed loop cam control (four cams, independent control)\u003cbr\u003eSequential fuel delivery\u003cbr\u003eDigital triggering, all OEM patterns\u003cbr\u003eOEM idle hardware supported\u003cbr\u003e5D boost control with three switchable tables\u003cbr\u003eMotorsport features - anti-lag, launch, flat shift\u003cbr\u003eContinuous barometric correction (onboard)\u003cbr\u003eCAN port\u003cbr\u003eQuick Tune - automated fuel tuning\u003cbr\u003eIndividual cylinder correction\u003cbr\u003eUSB tuning cable included\u003cbr\u003eStats recording into on-board memory\u003cbr\u003eGear compensations for spark, boost and fuel\u003cbr\u003eReal-time selectable dual fuel, ignition and boost maps\u003cbr\u003eSync and crank sensors can be a combination of Hall effect, variable reluctance or optical\u003cbr\u003eBoost control referenced to gear, speed or throttle position\u003cbr\u003e512 megabytes data logging memory\u003cbr\u003eStaged injection\u003cbr\u003eKnock with \"windowing\"\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eI\/O Expansion Options:\u003c\/h3\u003e\n\u003cp\u003eThe following expansion connector inputs\/outputs are provided: \u003cbr\u003e\u003cbr\u003e\u003cstrong\u003eExpansion connector:\u003c\/strong\u003e\u003cbr\u003eGnd Sensor Ground Only \u003cbr\u003e+5V Out Low Current +5V Supply \u003cbr\u003eDI 5 Digital Input for switching functions. \u003cbr\u003eDI 6 Digital Input for switching functions. \u003cbr\u003eDI 4 Digital Input for switching functions. \u003cbr\u003eAn Volt 4 Analog 0-5V input \u003cbr\u003eAn Volt 5 Analog 0-5V input \u003cbr\u003eAn Volt 6 Analog 0-5V input\u003c\/p\u003e\n\u003cp\u003eAn ignition expansion is provided allowing you to convert to a Direct Spark ignition system. Alternatively, these outputs can be used to drive auxiliary devices. The following pinout describes the available connections. \u003cbr\u003e\u003cbr\u003e\u003cstrong\u003eIgnition Expansion:\u003c\/strong\u003e\u003cbr\u003e1 Ignition 1 \u003cbr\u003e2 Ignition 2 \u003cbr\u003e3 Ignition 4 \u003cbr\u003e4 Ignition 3\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch5\u003eWhat's in The Box\u003cbr\u003e\n\u003c\/h5\u003e\n\u003ch3\u003eLink Toyota MR2Link V1 - TST185X PlugIn ECU\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eG4X PlugIn ECU\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWiring and Installation Instructions\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eStickers\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003cbr\u003e\n\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39270958858342,"sku":"TST185X","price":1145.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/LinkToyotaMR2LinkV1-TST185XPlugInECU.png?v=1616166790","url":"https:\/\/www.aimshop.com\/it\/products\/link-toyota-mr2link-v1-tst185x-plugin-ecu","provider":"AimShop.com","version":"1.0","type":"link"}
