Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    MV Agusta F3 675, F3 800, F4 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    MV-PP
    MV Agusta F3 675, F3 800, F4 1000 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    In magazzino, pronto per la spedizione
    £60.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £60.00
    MV Agusta F3 675, F3 800, F4 1000 Solo 2 DL & EVO4S Plug & Play Cable
    The AiM ECU plug & play cable has been specifically designed for MV Agusta bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    MV Agusta plug & play cable 7 pin - 712 male binder connection
    MV Agusta Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the MV Agusta bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
    The plug & play cable currently fits the following MV Agusta bike models:
    F3 675 - From 2012 F3 800 - From 2012
    F4 1000 - From 2013
    Example data protocols
    • Below is a pinout drawing for the MV Agusta Solo 2 DL & EVO4S Data Logger plug & play connection cable
    • MV Agusta F3 675, F3 800, F4 1000 Plug & Play connection cable
    Technical sheet Race Studio 3
