{"product_id":"aim-sw4-280-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 Volante Formula 280","description":"\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_bCFQLY\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eVolante con registrazione dati\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Il volante Formula Steering Wheel 4 270\/280 è tra i nostri volanti per il motorsport più avanzati fino ad oggi. È dotato di un data logger interno con configurazione completa, impugnature rimovibili, interruttori rotativi e una lunga lista di opzioni di connettività ECU e CAN completamente compatibili.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_3kEhi6\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePerché scegliere il \u003ctc\u003eAim\u003c\/tc\u003e Volante 270\/280\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Il volante Formula 270\/280 è stato progettato specificamente per applicazioni motorsport professionali. Il data logger interno è completamente configurabile ed è stato sviluppato per acquisire e visualizzare i dati dalla centralina, con oltre 1.000 protocolli ECU completamente compatibili.\u003c\/p\u003e  \u003cp\u003eLe nostre ruote Formula sono disponibili in una gamma di dimensioni (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca title=\"Aim SW4 GT320\/GT350 Formula Steering Wheel\" href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-formula-steering-wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003e). Le versioni compatte 270 e 280 sono la scelta ideale per monoposto o prototipi sportivi dove lo spazio nell'abitacolo è limitato. La differenza tra il volante Formula 4 270 e 280 è il diametro complessivo: il 280 è più grande di 10 mm per adattarsi alle diverse preferenze del pilota.\u003c\/p\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e SW4 Il volante Formula 270\/280 è inoltre pienamente compatibile con il nostro PDM32 tramite comunicazione CAN.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_cy4Jzy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eConnessione facile\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCollegamento del \u003ctc\u003eAim\u003c\/tc\u003e Collegare il volante Formula 270\/280 alla centralina è semplice. È possibile campionare decine di canali direttamente dalla centralina utilizzando un'unica connessione, anziché installare più sensori analogici.\u003c\/p\u003e  \u003cp\u003eI dati campionati dipendono dalla centralina elettronica in uso, ma in genere includono giri\/min, carico motore, posizione dell'acceleratore (TPS), temperature dell'olio, dell'aria e dell'acqua, pressione dell'olio, tensione della batteria, velocità, marcia e valori lambda (rapporto aria\/carburante). L'elenco dei driver ECU disponibili viene costantemente aggiornato e aggiornato e include oltre 1.000 diverse centraline.\u003c\/p\u003e  \u003cp\u003eGrazie all'uscita CAN, è possibile inviare messaggi direttamente a una rete CAN esistente, consentendo un'integrazione estesa con altri sistemi del veicolo.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_E8RKHy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay \u0026amp; Pulsanti\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Il volante Formula 4 270\/280 è dotato di un sistema di controllo ad alto contrasto 4.3\" Display TFT completamente configurabile e visibile alla luce del sole. Con 8 luci di cambio marcia, 4 LED di allarme RGB e un sensore di luce ambientale integrato, il volante fornisce informazioni chiare, precise e affidabili direttamente al conducente in ogni momento.\u003c\/p\u003e  \u003cp\u003eIl volante Formula 4 270\/280 è dotato di 10 pulsanti e 3 interruttori rotativi, tutti retroilluminati con LED RGB. Include inoltre impugnature rimovibili, interruttori rotativi e un'ampia gamma di opzioni di connettività ECU e CAN.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_nAJYLi\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAllarmi flessibili\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e SW4 Il volante Formula 270\/280 offre 8 LED RGB per le luci di cambio marcia e 4 LED RGB per gli allarmi. È possibile definire condizioni, colori, priorità e frequenze di lampeggio, nonché visualizzare messaggi di testo di accompagnamento quando necessario.\u003c\/p\u003e  \u003cp\u003eLe luci di cambio marcia RGB multicolore avanzate possono essere completamente personalizzate, con la possibilità di definire diversi schemi di cambio per ogni marcia.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_9enpXA\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eExtra opzionali\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePer sfruttare al meglio il tuo volante, è disponibile un'ampia scelta di accessori:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003ca title=\"Aim GPS09 Module\" href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\"\u003e\u003cstrong\u003eModulo GPS\u003c\/strong\u003e\u003c\/a\u003e:  Collegato tramite CAN, il modulo GPS semplifica l'analisi dei tempi sul giro e della posizione in pista.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003ePalette della frizione\u003c\/strong\u003e:  È possibile aggiungere le leve della frizione sinistra\/destra dagli accessori in cima alla pagina per adattarle al proprio stile di guida.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eAltre espansioni\u003c\/strong\u003e:  Espandi il tuo sistema con una gamma di funzionalità aggiuntive \u003ctc\u003eAim\u003c\/tc\u003e dispositivi, tra cui TC Hub, Lambda Controller, SmartyCam 3, RIO, GS-Dash e altri ancora.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270mm Numero parte: X07SW42700\u003c\/p\u003e  \u003cp\u003e280mm Numero parte: X07SW42800\u003c\/p\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":42989426016358,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03_1.5x.webp?v=1764769945","url":"https:\/\/www.aimshop.com\/it\/products\/obiettiviw4-280-formula-sterzo-volante","provider":"AimShop.com","version":"1.0","type":"link"}
