{"product_id":"aim-sw4-280-sim-racing-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 Volante 280 Sim Racing Formula","description":"\u003cdiv id=\"shopify-section-template--18120943861862__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eVolante con registrazione dati\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Volante Formula 270\/280 4 (SW4) è uno dei nostri volanti da simulazione di guida più avanzati fino ad oggi. Il volante Formula include un data logger interno con opzioni di configurazione complete, impugnature rimovibili, interruttori rotativi e integrazione software flessibile con la telemetria della simulazione.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePerché scegliere il volante Formula 270\/280\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Il volante Formula 270\/280 è stato progettato specificamente per i piloti di simulatori. Il data logger interno è completamente configurabile ed è stato progettato per acquisire e visualizzare i dati di telemetria direttamente dal software del simulatore. Grazie al supporto per un'ampia gamma di simulatori e protocolli di telemetria, è la scelta ideale per installazioni in abitacoli compatti dove lo spazio è limitato.\u003c\/p\u003e  \u003cp\u003eI nostri volanti Formula sono disponibili in una gamma di dimensioni (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-sim-racing-formula-steering-wheel\" title=\"Aim SW4 GT320\/GT350 Sim Racing Formula Steering Wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003e). La differenza tra la Formula SW4 Le dimensioni complessive del volante sono 270 e 280. Il volante Formula 280 è più grande di 10 mm per soddisfare le esigenze di ogni pilota.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eConnessione facile\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCollegamento del \u003ctc\u003eAim\u003c\/tc\u003e Collegare il volante Formula 270\/280 al tuo simulatore di guida è semplice. La telemetria viene ricevuta direttamente dal software di simulazione, il che significa che puoi campionare decine di canali senza bisogno di sensori fisici.\u003c\/p\u003e  \u003cp\u003eA seconda del simulatore di guida, i dati disponibili includono in genere giri al minuto, posizione dell'acceleratore, pressione dei freni, marcia, velocità, livello del carburante, dati degli pneumatici, tempi sul giro e altro ancora. La compatibilità con la telemetria viene costantemente aggiornata e ampliata, con il supporto per molti dei simulatori di guida più popolari.\u003c\/p\u003e  \u003cp\u003eCon l'uscita CAN, è possibile inviare messaggi ad altri \u003ctc\u003eAim\u003c\/tc\u003e dispositivi o espansioni per corse simulate, ampliando la gamma di opzioni di telemetria e controllo del tuo abitacolo.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay \u0026amp; Pulsanti\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl volante da corsa Formula 270\/280 ha un contrasto elevato 4.3\" Display TFT completamente configurabile e facile da leggere in ogni condizione. Grazie al sensore di luce ambientale, il display regola automaticamente la luminosità per rimanere nitido e confortevole.\u003c\/p\u003e  \u003cp\u003eIl volante Formula è dotato anche di 10 pulsanti e 3 interruttori rotanti, tutti retroilluminati con LED RGB per una maggiore facilità d'uso nel tuo simulatore di corse.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAllarmi flessibili\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIL \u003ctc\u003eAim\u003c\/tc\u003e Il volante Formula 270\/280 sim racing è dotato di 8 LED RGB per le luci di cambio marcia e 4 LED RGB per gli allarmi. È possibile scegliere le condizioni e i colori, fissi o lampeggianti, le frequenze di lampeggio e visualizzare messaggi sullo schermo.\u003c\/p\u003e  \u003cp\u003eGrazie alle luci di cambio marcia integrate, puoi scegliere tra una serie di avanzati modelli di luci di cambio marcia RGB multicolore, personalizzabili in base alle tue esigenze e persino configurabili per ogni marcia.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eExtra opzionali\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePer sfruttare al meglio il tuo volante, è disponibile un'ampia scelta di accessori:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003cstrong\u003ePalette della frizione\u003c\/strong\u003e:  Offriamo un kit di palette frizione con le palette inferiori sinistra e destra, oppure puoi acquistarle separatamente, sia per la leva sinistra che per quella destra. Consulta le opzioni in cima alla pagina per acquistare la tua.\u003c\/li\u003e  \u003cli\u003e  \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\" title=\"Aim GPS09 Module\"\u003e\u003cstrong\u003eModulo GPS\u003c\/strong\u003e\u003c\/a\u003e:  Se utilizzato in ambienti di simulazione, il modulo GPS consente il calcolo del tempo sul giro e l'analisi della posizione della pista virtuale, con un database di migliaia di circuiti disponibili.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270mm Numero parte: X07SW42700\u003c\/p\u003e  \u003cp\u003e280mm Numero parte: X07SW42800\u003c\/p\u003e","brand":"AiM Sim","offers":[{"title":"Default Title","offer_id":43332277895270,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03_1.5x_5de7949e-284b-4be0-987d-7b3aa17def08.webp?v=1761207560","url":"https:\/\/www.aimshop.com\/it\/products\/obiettiviw4-280-sim-racing-formula-steering-wheel","provider":"AimShop.com","version":"1.0","type":"link"}
