1 di 12
Remote Button CAN Interface Pro Keypad
SKU: RBI-B4-PRO
Prezzo regolare
£240.00
Prezzo regolare
Prezzo di vendita
£240.00
Control Your Vehicle At Your Fingertips
The Remote Button CAN Interface Pro Keypad is a high-performance, customisable keypad designed to enhance vehicle control in motorsport applications. Available in 4, 6, 8, 10, 12 and 15-button options, they allow drivers to tailor their control systems to their specific needs.
Pro Keypad Key Features
Configurable Channels
Multicolour Indicator Rings
CAN Bus Compatible Keypad
LED Status Configurable
LED-Backlit Icons
Vertical or Horizontal Mount
CAN Interface Keypad
The Aim remote button CAN interface keypads will enable you to have your very own selected buttons at your fingertips. The keypads are designed to a high standard to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil and chemicals.
The Pro keypads are available in 4, 6, 8, 10,12 and 15 to suit your requirements.
Important: 12 KEY AND 15 KEY CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
Easy To Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note: The keypads come blank with no inserts.
With Race Studio 3, you can create, modify, delete, import, and export configurations for all channels, ECU drivers, math channels, display pages, digital outputs, alarms, shift lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.
*Please be aware that our PRO Keypads will require a more complex configuration than our Standard CAN Keypads but will add more customisability and features. If you would like to use the easy configuration method built into Race Studio 3, you must buy our Standard CAN Keypad.
Race Studio 3 also allows you to download and analyse all data recorded by the data logging system. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
  • Remote Button CAN Interface Pro Keypad
LED-Backlit Icons
Easy To Read
Technical Specifications
What's In The Box
