{"product_id":"second-life-aim-mxs-1-3-strada-5-tft-dash-display-with-road-icons","title":"Second-Life Aim MXS 1.3 Strada 5\" TFT Dash Display with Road Icons","description":"\u003cp style=\"display: none;\"\u003eIl display MXP 1.3 è una scelta popolare per i piloti e i team di sport motoristici, offrendo il monitoraggio dei dati in tempo reale \u0026e registrazione dei dati sulle prestazioni su un display TFT da 6 pollici di alta qualità.\u003c\/p\u003e  \u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDash Logger avanzato per sport motoristici\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl registratore del display del cruscotto dell'auto MXP ha un 6\" Display digitale TFT, progettato per acquisire e visualizzare i dati provenienti dalla centralina. È la scelta ideale per i piloti che desiderano avere dati preziosi a portata di mano, ma che potrebbero avere problemi di spazio nell'abitacolo.\u003c\/p\u003e  \u003cp\u003e\u003cstrong\u003eNota\u003c\/strong\u003e: IL \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mxp-strada-6-tft-dash-display-with-road-icons\" title='Aim MXP 1.3 Strada 6\" TFT Dash Display with Road Icons'\u003eMXP Strada \u003c\/a\u003eè disponibile anche l'opzione con icone stradali per adattarsi a una varietà di applicazioni del veicolo.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eConnessione facile\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCollegare il cruscotto MXP 1.3 alla centralina dell'auto è semplice. È possibile campionare decine di canali direttamente dalla centralina. Questa è solitamente la configurazione più rapida e semplice, che richiede solo un collegamento via cavo alla centralina, anziché molteplici connessioni e sensori analogici.\u003c\/p\u003e  \u003cp\u003eI dati campionati dipenderanno dalla centralina motore effettiva, ma in genere includono giri\/min, carico motore, posizione dell'acceleratore (TPS), temperatura dell'olio, dell'aria, dell'acqua, pressione dell'olio, tensione della batteria, velocità, marcia e valore lambda (rapporto aria\/carburante). L'elenco dei driver ECU disponibili viene costantemente aggiornato e aggiornato e include oltre 1.000 diverse centraline.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDue uscite digitali\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl registratore MXP per display da cruscotto è dotato di due uscite digitali. Ciascuna di esse può erogare una corrente di 1 ampere a 12 volt. Possono essere configurate per essere accese\/spente in base al valore degli ingressi analogici o digitali. Consentono il funzionamento automatico di sistemi esterni, come l'accensione\/spegnimento di luci supplementari, l'attivazione\/disattivazione di una ventola di raffreddamento o di pompe di circolazione al verificarsi di un determinato evento.\u003c\/p\u003e  \u003cp\u003eGrazie all'uscita CAN è possibile inviare messaggi anche direttamente a una rete CAN esistente, ampliando così le possibilità di controllo del veicolo.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay configurabile\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eCon un contrasto elevato 6\" Grazie al display TFT completamente configurabile, è possibile creare e personalizzare pagine\/display in base alle proprie esigenze. Il passaggio da una pagina all'altra può essere gestito premendo uno o due pulsanti. Un sensore di luce ambientale regola la retroilluminazione per una luminosità ottimale, garantendo una visibilità ottimale in tutte le condizioni di illuminazione.\u003c\/p\u003e  \u003cp\u003eSono disponibili due ingressi per telecamere analogiche per trasformare il display in un\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003etelecamera a specchio\u003c\/a\u003e, tramite comando a pulsante o gestione eventi. La telecamera è venduta separatamente.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAllarmi flessibili\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIl registratore di allarme MXP per cruscotto auto è dotato di 6 LED RGB configurabili. È possibile scegliere le condizioni e i colori. È possibile selezionare un allarme fisso o lampeggiante e la frequenza di lampeggio. È possibile scegliere di ricevere un messaggio di testo di accompagnamento e impostare le priorità di allarme.\u003c\/p\u003e  \u003cp\u003eGrazie alle luci di cambio marcia integrate, puoi scegliere tra una serie di avanzati modelli di luci di cambio marcia RGB multicolore, personalizzabili in base alle tue esigenze e, se necessario, per ogni marcia specifica.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17972742553702__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eOpzioni GPS\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eL'incluso\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/collections\/aim-gps-lap-timing\" title=\"GPS \u0026amp; Lap Timing\"\u003eModulo GPS09\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eCollegato tramite CAN al dash logger MXP, semplifica il calcolo dei tempi sul giro e l'analisi della posizione in pista. Con oltre 4.000 circuiti in tutto il mondo già memorizzati con le coordinate di partenza e arrivo, non avrai problemi quando sarai in pista.\u003c\/p\u003e  \u003cp\u003eNon appena l'MXP viene acceso, il modulo GPS ne localizzerà la posizione, identificherà le coordinate del tracciato e inizierà immediatamente a rilevare tempi sul giro e intermedi. Se il tracciato non è presente nel database, è possibile aggiungere facilmente le coordinate del traguardo all'MXP utilizzando il nostro software Race Studio 3.\u003c\/p\u003e  \u003cp\u003eIl modulo GPS è disponibile con cavi lunghi 50 cm, 1,3 m, 2 m o 4 m, oppure in una versione da tetto con cavi lunghi 2 m o 4 m.\u003c\/p\u003e  \u003cp\u003e\u003cstrong\u003eNotare che\u003c\/strong\u003e: Un cablaggio a 37 pin è incluso di serie nel kit. Se hai bisogno di più dati, puoi aggiungere il nostro\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-22-pin-deutsch-harness-mx-series\" title=\"Aim 22 Pin Deutsch Harness for MX Series\"\u003ecablaggio a 22 pin\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003ecome extra opzionale.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h2\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45631692996710,"sku":"SN 5308114","price":824.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXSStrada_0dcf443e-19d3-4ed1-8437-8e8672d8e4c3.png?v=1779115199","url":"https:\/\/www.aimshop.com\/it\/products\/second-life-aim-mxs-1-3-strada-5-tft-dash-display-with-road-icons","provider":"AimShop.com","version":"1.0","type":"link"}
