1 di 4
Yamaha YZF-R1 (2004-2008) & YZF-R6 (2006-2016) AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-YAM-2-V0256919CS-X47SOLO2DL02
Prezzo regolare
£710.00
Prezzo regolare
Prezzo di vendita
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Yamaha ECU connection cable
This kit has been specifically designed for Yamaha bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.
Yamaha YZF-R1 (YEC included) - 2004-2008 Yamaha YZF-R6 (YEC included) - 2004-2016
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Yamaha YZF-R1 & YZF-R6 plug & play connections cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Yamaha Connection Cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 2 spacers
  • 4 washers M6
  • 2 washers M4
