4 Button Handlebar Control Switches for Motorcycle
SKU: SP229
- 通常価格
- £215.00
- 通常価格
- セールスプライス
- £215.00
- 単価
- あたり
+ VAT(英国のみ)
This four-button custom configuration switch has been designed for use on race & track bikes with the standard ECU, and where lights and turn signals are not needed.
The aluminium assembly has been ergonomically designed for easy use and encompasses four sealed momentary switches, which are black in colour and metal bezel. The rugged machine aluminium construction and fully waterproof switches provide greater crash protection and electrical integrity.
The four-way button is all black in colour & metal bezel
Common Ground
400mm DR25
All Switches are momentary N/O
Black - Common Ground
Laser engraved 1 > 4
- 4-way button
- Width at the centre: 13.5mm
- Colour: Black
- Metal Bezel
- Common Ground
- 400mm DR25
- All switches are momentary N/O
- Black: Common Ground
- Switch Sealing: IP67
- Laser Engraved: 1 - 4
- Wire colours are: 1 - Red, 2 - Green, 3 - White, 4 - Blue
- SP229 - BD-SW-4B
- 1 x 4 Button Handlebar Control Switch
Common Ground
400mm DR25
- 4-way button
- Colour: Black
- Metal Bezel
- Common Ground
- 400mm DR25
- SP229 - BD-SW-4B
- 選択を選択すると、ページ全体が更新されます。
