AiM 37 Pin Deutsch Harness with 1 Thermocouple MXS, MXP, MXG, MXL2, MXm Car
SKU: H37-ST-V02573040
- 通常価格
- ¥71,500
- 通常価格
- セールスプライス
- ¥71,500
- 単価
- あたり
+ VAT(英国のみ)
The AiM 37 pin Deutsch Harness with one thermocouple connector to connect a K-Line type sensor.
Suitable for MXS, MXP, MXG, and MXL2. MXm | Digital output |
37 pin harness | One thermocouple connector |
37 pin Harness with One Thermocouple Connector for the MX Series
The AiM 37 pins harness has been designed with one thermocouple connector, this will enable you to connect a thermocouple sensor to your device.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is a 37 pins Deutsch harness with two thermocouple connectors, available in the Accessories Tab.
- 37 pin Deutsch Female Flying Connector
- 5 pins Binder 712 Female Connector - See table in Downloads Tab
- 7 none ended cables - See table in Downloads Tab
- Female Thermocouple Connector - See table in Downloads Tab
- 37 pin Deutsch Harness
The AiM 37 pin Deutsch Harness with one thermocouple connector to connect a K-Line type sensor.Key Features :
The AiM 37 pins harness has been designed with one thermocouple connector, this will enable you to connect a thermocouple sensor to your device.This harness can be used to replace a damaged harness or for a second vehicle installation when sharing a dash logger.
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
- 選択を選択すると、ページ全体が更新されます。
