AiM 712-712 Male to Female 5 Pin CAN Patch Lead Motocross
SKU: P-712-712-5-5-V02552690
- 通常価格
- £40.00
- 通常価格
- セールスプライス
- £40.00
- 単価
- あたり
AiM CAN cables link modules or hardware on the AiM-specific CAN system (Controller Area Network). These cables transfer data or power from one AiM component to another.
712-712 patch lead | 5 pin male to female |
Extends wiring harness | Various lengths available |
AiM CAN cable connect hardware components in the AiM CAN system (Controller Area Network). You would use these cables to connect Channel Expansion Hubs, ECU Bridge, Lambda Controller, GPS module, and any other peripheral hardware to a Data Hub. Or from the Data Hub to the dash/logger harness. These cables use the metal Binder 712 screw-on connectors with 5-pins in the housing. They are available in various lengths.
AiM CAN cables link modules or hardware on the AiM-specific CAN system (Controller Area Network). These cables transfer data or power from one AiM component to another. It should not be confused with the CAN system in your car's factory wiring. They are separate CAN systems. Only in specific cases will an AiM CAN component interface with a vehicle CAN component, such as linking vehicle ECU data to a data logger.
- 712-712 5 pins Male to Female CAN Patch Lead
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
- 1 x 712-712 Male to Female 5 Pin CAN Patch Lead
AiM CAN cables link modules or hardware on the AiM-specific CAN system (Controller Area Network). These cables transfer data or power from one AiM component to another.Key Features :
AiM CAN cable connect hardware components in the AiM CAN system (Controller Area Network). You would use these cables to connect Channel Expansion Hubs, ECU Bridge, Lambda Controller, GPS module, and any other peripheral hardware to a Data Hub. Or from the Data Hub to the dash/logger harness. These cables use the metal Binder 712 screw-on connectors with 5-pins in the housing. They are available in various lengths.AiM CAN cables link modules or hardware on the AiM-specific CAN system (Controller Area Network). These cables transfer data or power from one AiM component to another. It should not be confused with the CAN system in your car's factory wiring. They are separate CAN systems. Only in specific cases will an AiM CAN component interface with a vehicle CAN component, such as linking vehicle ECU data to a data logger.
- 50cm
- 100cm
- 150cm
- 200cm
- 250cm
- 300cm
![AiM 712-712 Male to Female 5 Pin CAN Patch Lead Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/712_-_712_0.50cm_5_Pin_Patch_Lead_364d787e-b085-49d8-947e-0c5cee371845_1445x.png?v=1613403954)
![AiM 712-712 Male to Female 5 Pin CAN Patch Lead Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiM712-712MaletoFemale5PinPatchLead1_df7be4e5-97c2-47f9-af67-652216372ed3_1445x.png?v=1613403954)
![AiM 712-712 Male to Female 5 Pin CAN Patch Lead Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiM712-712MaletoFemale5PinPatchLead2_de3f2048-94e1-4d4d-85ab-3d6ea3aadf87_1445x.png?v=1613403954)
![AiM 712-712 Male to Female 5 Pin CAN Patch Lead Motocross - AimShop.com](http://www.aimshop.com/cdn/shop/products/712_-_712_2m_5_Pin_Patch_Lead_09494c33-b936-443d-88da-f7d857742320_1445x.png?v=1613403954)
- 選択を選択すると、ページ全体が更新されます。
