AiM Taipan Second Injection Harness
SKU: C-H-IN
- 通常価格
- £30.00
- 通常価格
- セールスプライス
- £30.00
- 単価
- あたり
The AiM Taipan second injection harness is connected to the 3rd connector on the Taipan ECU.
Second injection harness | 2500cm length |
AiM Taipan Accessories
The AiM Taipan second injection harness is connected to the 3rd connector on the JST connection Taipan ECU.
The patch lead is connected to the JST connector on the Taipan ECU and is available in 2500cm cable. With two flying leads - Red wire 12V second injection and a Black wire - second injection CMD.
UC Bridge - Optional Extra
User License:
A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
The UC Bridge is required for two functions:
Tuner License:
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections - Optional Extra
The Taipan ECU has 4 connectors:
The Aim Handlebar Switch is the best way for changing the behaviour of your bike; it features 2 pushbuttons, 10 LEDs and manages the following settings:
- JST Connector 08T-JWPF-VSLE-D
- Red Wire - 12V Second INJ
- Black Wire - Second INJ CMD
- Full length - 2500cm
- Second injection harness - 2500cm
The AiM Taipan second injection harness is connected to the 3rd connector on the Taipan ECU.Key Features :
The AiM Taipan second injection harness is connected to the 3rd connector on the JST connection Taipan ECU.The patch lead is connected to the JST connector on the Taipan ECU and is available in 2500cm cable. With two flying leads - Red wire 12V second injection and a Black wire - second injection CMD.
User License:
Tuner License:
Video
- 選択を選択すると、ページ全体が更新されます。
