{"product_id":"aim-front-wheel-hub-speed-pickup-sensor","title":"Aim Front Wheel Hub Speed Pickup Sensor","description":"\u003ch3\u003eAim Front Wheel Hub Speed Pickup Sensor\u003c\/h3\u003e\n\u003cp\u003eThis Aim device can measure the kart's front wheel speed using a non-contact sensor that needs a magnetic metallic trigger to pass in front of it.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSpeed sensor\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e712 - 4 pin binder connector\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eMagnetic trigger\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eAim Front Wheel Hub Speed Pickup Sensor\u003c\/h3\u003e\n\u003cp\u003eThis AiM device can measure the kart's front wheel speed using a non-contact sensor that needs a magnetic metallic trigger to pass in front of it.\u003cbr\u003eThe sensor kit includes a metal plate with a magnetic cylinder and a metallic bracket the sensor is welded to.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eEasy Installation\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eInstall the magnetic plate on the front wheel rim.\u003cbr\u003eInstall the bracket onto the steering arm; if the steering arm is solid, make a hole with a 6mm drill bit.\u003cbr\u003eWhen mounting the bracket, ensure that the sensitive part passes in front of the cylinder at a 3-5mm distance.\u003cbr\u003eFirmly fix the bracket to the steering arm to avoid sensor movements due to the intense vibrations of the Kart front wheel.\u003cbr\u003eEnsure the bracket does not get in contact with the metallic plate when steering.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\" data-mce-style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/aim-academy\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Academy_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/aim-technologies-support\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/race-studio-3-download\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAim Front Wheel Hub Speed Pickup Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eThe sensor electrical characteristics are:\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eSensing Distance: From 3.5mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eNumber of pulses for wheel revolution: 1\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Front_Wheel_Hub_Speed_Pickup_Sensor.png?v=1629382341\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Front Wheel Hub Speed Pickup Sensor\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e1 x Aim Front Wheel Hub Speed Pickup Sensor\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\" data-mce-style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_KartFrontSpeed_102_eng.pdf?v=1603711832\" title=\"AiM Technical Sheet\" target=\"_blank\"\u003e\u003cimg data-mce-fragment=\"1\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\" data-mce-src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Datasheet_KartFrontSpeed_102_eng.pdf?v=1603711832\" title=\"AiM Technical Sheet\" target=\"_blank\"\u003eTechnical Sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\u003ca title=\"Aim Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\" data-mce-style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Aim Sensors","offers":[{"title":"Default Title","offer_id":29382036422758,"sku":"S-S-K-F","price":70.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_frontWheelSpeedSensor_00_1.5x.webp?v=1761578003","url":"https:\/\/www.aimshop.com\/ja-jp\/products\/aim-front-wheel-hub-speed-pickup-sensor","provider":"AimShop.com","version":"1.0","type":"link"}
