AiM GPS09 Module GPS Roof Mount Version
SKU: GPS-CR2
- 通常価格
- ¥59,100
- 通常価格
- セールスプライス
- ¥59,100
- 単価
- あたり
+ VAT(英国のみ)
AiM GPS09 Roof Version Module
This roof version is available in 2m or 4m and specifically designed for easy installation. This version also works well when fitted to race bike fairings, as the module can be bolted through the fairing with the advantage that the cable can be detached at the GPS module making removal quicker and more convenient.
GPS09 Benefits
On the Track
AiM GPS09 Module
- Weight: 60.5g
AiM GPS09 Module
- GPS09 Module
GPS09 Benefits
On the Track
AiM GPS09 Module
- Weight: 60.5g
AiM GPS09 Module
- GPS09 Module
- 選択を選択すると、ページ全体が更新されます。
