AiM LCU-One Lambda Controller Replacement Weld on Bung Motocross
SKU: LCU-FR-MX
- 通常価格
- £10.00
- 通常価格
- セールスプライス
- £10.00
- 単価
- あたり
The AiM steel LCU-One Lambda Controller replacement weld-on bung.
Replacement weld-on bung | Steel Bung |
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.
The female-threaded steel connectors feature a natural finish.
The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.
- Weld-on Bung
- 24.7mm (1.5mm)
- x 1 Weld on Bung 24.7mm (1.5mm)
The AiM steel LCU-One Lambda Controller replacement weld-on bung.Key Features :
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.The female-threaded steel connectors feature a natural finish.
Optional Extras
The above image shows how you can put a system together to increase your data performance. ![]() |
- Weld-on Bung
- 24.7mm (1.5mm)
- 選択を選択すると、ページ全体が更新されます。
