Aim MXK10 Kawasaki Ninja ZX-10R (Gen 4 2011-2015) Plug & Play Dash Logger
SKU: MXK10-GEN4
- 通常価格
- £995.00
- 通常価格
- セールスプライス
- £995.00
- 単価
- あたり
Kawasaki ZX-10R Gen 4 Dash
Upgrade your Kawasaki Ninja ZX-10R Gen 4 (2011-2015) with the Aim MXK10 Dash Logger – the ultimate plug & play racing display designed for professional and track-day riders. Whether you're pushing lap times on the track or optimising your bike’s performance, the MXK10 dashboard provides real time data, precise lap timing and seamless ECU integration.
5" TFT Display | 4GB Memory |
GPS Module Included | Full ECU Data Logging |
10 Shift Light LEDs | 6 Status RGB LEDs |
Wi-Fi Connectivity | Plug & Play Connection |
Why Choose The MXK10 Gen 4 Kawasaki Dash?
The Aim MXK10 Dash is engineered specifically for the Kawasaki ZX-10R Gen 4 (2011-2015), ensuring full compatibility with the ECU. It’s the perfect upgrade for riders looking for precision, performance and seamless integration with their bike’s systems.
Please Note: The MXK10 dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order.
Advanced Display & LED System
The 5” high-contrast TFT display ensures crystal-clear visibility of your ride data, even in bright sunlight. Customisable shift light LEDs provide an intuitive visual guide, helping you optimise gear shifts and maximise performance on the track.
Lap Timing & Data Logging
Equipped with a 25 Hz GPS09 module, the MXK10 Kawasaki Dash provides millisecond-accurate lap timing, automatic track recognition and track mapping capabilities. Once the bike is switched on near a known track, the GPS module automatically loads the start/finish coordinates, calculating lap times with precision. Note: If a track is missing, it can be created and added via Race Studio 3.
The MXK10 Kawasaki Dash is compatible with various expansions and modules to enhance performance and expand on data collection. Some of the compatible expansions include:
Race Studio 3 also allows you to download and analyse all data recorded by your MXK10 Kawasaki Dash. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
- Display: 5"" TFT
- Resolution: 800x480 pixels
- Contrast: 600:1
- Ambient Light Sensor: Yes
- Status information LEDs: 6
- Shift Lights LEDs: 10
- CAN connections: 2
- ECU connection: Yes
- External Modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
- Internal memory: 4 GB
- Body: 1 JAE connector & 2 Binder connectors
- Dimensions: 166 x 97 x 23mm
- Weight: 530g
- Power consumption: 400 mA
- MXK10 Gen 4 Dash Logger
- Screws & Washers
- GPS Module Roof Version
- Anodised plate fixing kit & screws
- Display: 5"" TFT
- Contrast: 600:1
- Weight: 530g
- Screws & Washers
- 選択を選択すると、ページ全体が更新されます。
