AiM MyChron5 Temperature Sensor 712-719 3 Pin Patch Lead
SKU: P-712-719-15-3
- 通常価格
- £40.00
- 通常価格
- セールスプライス
- £40.00
- 単価
- あたり
+ VAT(英国のみ)
The AiM 712-719 MyChron5 temperature sensor 712-719 3 pin patch lead.
712-719 patch lead | 3 pin male to female |
High-quality connectors | Suitable for MyChron |
The AiM temperature sensor 712-719 patch lead has a four-pin female connector and a three-pin male connector. AIM Motorsport sensor for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4).
Designed to perform in challenging motorsport environments
Ideal to have as a spare
Suitable for AIM Motorsport kart temperatures sensors
Cable Length - 1500mm
- MyChron5 712-719 3 pin Patch Lead
- Metallic male Binder 3 pin
- Plastic female Binder Connector 4 pin
- Length: 1500mm
- 1 x 712-719 Temperature Sensor 3 pin Patch Lead
The AiM 712-719 MyChron5 temperature sensor 712-719 3 pin patch lead.Key Features :
The AiM temperature sensor 712-719 patch lead has a four-pin female connector and a three-pin male connector. AIM Motorsport sensor for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4).Designed to perform in challenging motorsport environments
- Length: 1500mm
- 選択を選択すると、ページ全体が更新されます。
