製品情報にスキップ
1 2
Aim PDM32,10" Display With Road Icons & GPS Data Logging Kit
SKU: PDM-32-...
通常価格
£2,275.00
£2,730.00
INC VAT - UK only
通常価格
セールスプライス
£2,275.00
通常価格
£2,275.00
£2,730.00
INC VAT - UK only
通常価格
セールスプライス
£2,275.00
The Aim PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. The 10" TFT display with road icons features a fully configurable display with a range of layouts to choose from and a GPS Module providing easy lap timing and lap position for track mapping.
32 RGB LEDs Eight analogue digital inputs
GPS lap timing (optional) Four digital inputs
28 High side outputs 4 Half-bridge outputs
Power Distribution Module
The Aim PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
The PDM32 can receive data from the vehicle ECU and even includes a data logger and GPS Module for lap timing and track mapping. The GPS Module is available with cables from 50cm up to 4m. There is also a GPS roof version available in 2m or 4m.
PDM32 Power Outputs
PDM32 Inputs
PDM32 Data Management
Dash Display 10" Road Icons
10" TFT display Road Icons
Six - Status LEDs Ten - Shift light LEDs
The display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. You can find the optional Reversing Mirror Camera in the Accessories Tab.
Optional Wiring Solutions:
  • Inputs:
  • 14 Fully Configurable, max 500 Hz each:
  • 8 analogue/digital
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • 4 rated up to 20 A (high power)
  • 12 rated up to 15 A (mild power)
  • 12 rated up to 10 A (low bridge)
  • 4 rated up to 35 A (half-bridge)
  • Protected for: over voltage, under voltage, over current, over temperature
  • Total max current: 120 A
  • LEDs: 32 RGB LEDs + 1 PDM ON + 1 PDM STS (Status)
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal platform: 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Remote Display Connection: 1 Aim stream output
  • Connectors: 2 AMP connectors + 2 Binder connectors + 1 Amphenol Surlok connector + 1 Rosenberger connector
  • Internal memory: 4 GB
  • External modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module
  • External Analogue Camera input: 2
  • Body: Anodised Aluminium
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • PDM Dash 10" TFT Display:
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Brightness: 800cd/m2
  • Ambient Light Sensor: Yes
  • Status information LEDs: 6
  • Shift Light LEDs: 10
  • Pushbutons: Metallic
  • Dimensions: 278.0 x 135.0 x 26.2mm
  • Weight: 1000 g
  • Power Consumption: 250 mA
  • GPS Module:
  • 5 Pin Binder connection
  • Weight: 60.5g
  • Power Distribution Module PDM32
  • TFT Screen 10" Road Icons
  • GPS Module
  • x 2 35 pins AMP Connector
  • Surlock Connector
  • Rosenberger LVDS Connector
  • CAN EXP Cable
  • Download Cable
The Aim PDM32 is a 32 channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. The PDM32 can receive data from the vehicle ECU and even includes a data logger and GPS Module for lap timing and track mapping. The GPS Module is available with cables from 50cm up to 4m. There is also a GPS roof version available in 2m or 4m.
PDM32 Power Outputs
The PDM32 features 28 high sided outputs and four half-bridge outputs: 4 x rated up to 20A (high power), 12 x rated up to 15A (mid-power), 12 x rated up to 10A (low power), 4 x rated up to 35A (half-bridge). Total continuous max current 120A. Each output provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retires, and the time between the reties is user-definable. All outputs can be configured as PWM's for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
PDM32 Inputs
The PDM32 can receive and record data from the following sources, ECU - Over 1000 protocols available. Digital/analogue inputs. Internal nine-axis EMU. GPS - Lap time and position. Expansion modules. Push buttons - From RIO02 (Remote Input Output module) or any commercial CAN keypad. PDM outputs - Currents and status of each channel individually. Other user-defined math channels.
The GPS09 module option provides easy lap timing and lap position for track mapping. The PDM has over 4000 race tracks in the database, so once you arrive at the track, the system already knows the timing points so that you can get on with the driving. The GPS09 module is available with various lead lengths to suit different applications and with cable entry from underneath (roof version) or the side. With a 5 pin binder connection.
  • Inputs:
  • 4 digital inputs
  • 2-speed input
  • Power Outputs:
  • Lin Bus: 1
  • Weight: 761g
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Weight: 1000 g
  • GPS Module:
  • Weight: 60.5g
  • GPS Module
  • Surlock Connector
  • CAN EXP Cable
  • Download Cable
