AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Kart
SKU: SM-VB-GP-K
- 通常価格
- ¥15,300
- 通常価格
- セールスプライス
- ¥15,300
- 単価
- あたり
+ VAT(英国のみ)
Clamp to a wide range of diameter tubing | For SmartyCam GP HD 2.1 & 2.2 |
Roll Cage Mount
- Arm height 60mm ( 2.36 inches)
- Handlebar bracket
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) roll cage mount has been designed to hold and position the bullet camera.Key Features :
The AiM SmartyCam GP HD 2.1 & 2.2 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 bullet camera.The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters.
Roll Cage Mount
Includes a handlebar bracket, and a rubber lining to prevent slipping and vibrations.Also, the bullet cam bracket can be positioned for your required viewing.
- Handlebar bracket
- 60mm arm
- Ball head
- 選択を選択すると、ページ全体が更新されます。
