{"product_id":"aim-solo-2-dl-plug-play-cable-tm-racing-motocross-ecu","title":"Aim Solo 2 DL Plug \u0026 Play Cable for TM Racing Motocross ECU","description":"\u003ch3\u003eAim Solo 2 DL Plug \u0026amp; Play Cable for TM Racing Motocross ECU\u003c\/h3\u003e\n\u003cp\u003eThe Aim ECU plug \u0026amp; play cable has been specifically designed for TM Racing bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.\u003c\/p\u003e\n\u003ch4\u003eKey Features:\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eTM Racing plug \u0026amp; play cable\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e7 pin - 712 male binder connection\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eReceive data\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for Solo 2 DL \u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eTM Racing Plug \u0026amp; Play ECU Cable\u003c\/h3\u003e\n\u003cp\u003eThe Aim ECU plug \u0026amp; play cable has been specifically designed for the TM Racing bike. This plug \u0026amp; play cable can be used for the Solo 2 DL.\u003c\/p\u003e\n\u003cp\u003eThe cable is an easy fitment to your bike and allows ECU data to be logged. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003ePlease Note:\u003c\/strong\u003e If you are unsure whether this ECU cable will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003ePlug \u0026amp; Play\u003c\/h3\u003e\n\u003cp\u003eThe plug \u0026amp; play cable currently fits the following TM Racing bike models:\u003c\/p\u003e\n\u003cdiv class=\"OTechMXDiv OTechMXDiv-2cols OTechMXDiv-Responsive\"\u003e\n\u003cdiv class=\"OTechMXDiv-Col OTechMXDiv-Sub\"\u003e\u003cimg class=\"MX-FitmentBike\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Motocross_TM_Racing_Solo_2_DL_Plug_Play_Lead_TM_Racing_Bike.png?v=1621424113\" alt=\"Aim Cobra ECU For Honda Motocross Bikes\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"OTechMXDiv-Col OTechMXDiv-Sub\" style=\"display: flex !important; flex-direction: row; flex-wrap: wrap;\"\u003e\n\u003cdiv class=\"MotocrossFitment\"\u003e\n\u003ctable class=\"MotocrossFitmentTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003cth colspan=\"2\"\u003e\u003cimg class=\"MX-FitmentManufacturer\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/TM_Racing_Logo.png?v=1621426113\"\u003e\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"MotoCell\"\u003eSMX 450 F1 - From 2015\u003c\/td\u003e\n\u003ctd class=\"MotoCell\"\u003eMX 250 F1 - From 2015\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"MotoCell\"\u003eMX 450 F1 - From 2015\u003c\/td\u003e\n\u003ctd class=\"MotoCell\"\u003eEN 250 F1 - From 2015\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"MotoCell\"\u003eEN 450 F1 - From 2015\u003c\/td\u003e\n\u003ctd class=\"MotoCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eExample data protocols\u003c\/h3\u003e\n\u003cp\u003eExample data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Solo_2_Connection_Example.png?v=1614780014\" style=\"width: 100%;\"\u003e\u003c\/h3\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your bike for incrementing performance and data.\u003c\/p\u003e\n\u003ch4\u003e\u003cbr\u003e\u003c\/h4\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAim Motocross TM Racing Solo 2 DL Plug \u0026amp; Play Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBelow is a pinout drawing for the TM Racing Solo 2 DL plug \u0026amp; play connection cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Motocross_TM_Racing_Solo_2_DL_Plug_Play_Lead_Technical_Sheet.png?v=1621424590\" alt=\"\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Motocross TM Racing Solo 2 DL Plug \u0026amp; Play Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTM Racing Plug \u0026amp; Play connection cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SoloDL_TMRacing_SMX450_MX250-450_EN250-450_2015_100_eng_06406fc6-37e6-49c9-8a7b-c9d1c67a2db8.pdf?v=1621428277\" title=\"TM Racing Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SoloDL_TMRacing_SMX450_MX250-450_EN250-450_2015_100_eng_06406fc6-37e6-49c9-8a7b-c9d1c67a2db8.pdf?v=1621428277\" title=\"TM Racing Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":31987967983718,"sku":"TM-MX-PP","price":70.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_tmracing_solo2dl_plugandplaycable_00.webp?v=1781610633","url":"https:\/\/www.aimshop.com\/ja-jp\/products\/aim-solo-2-dl-plug-play-cable-tm-racing-motocross-ecu","provider":"AimShop.com","version":"1.0","type":"link"}
