製品情報にスキップ
1 4
AiM Solo, Solo 2 & Solo 2 DL Brackets
SKU: SOLO-VB
通常価格
£67.00
通常価格
セールスプライス
£67.00
注文すべてでカーボンニュートラルな配送
We offer three different brackets to enable you to mount your Solo GPS lap timer to your preferred vehicle. Check out the options below.
Key Features:
Secure mounting for GPS lap timer Ball & socket for positioning
Suitable for Solo, Solo 2 & Solo 2 DL
AiM Roll Bar Mount for Solo GPS Lap Timer - Option 1
The AiM Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
The bracket will securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap timers to your preferred vehicle. The V bracket adjusts utilising a ball and socket type system for optimum positioning and clamps to a roll bar, railing or tube.
The duel swivel joint makes the viewing angle adjustment quick and easy, and the securing clip has a rubber lining to prevent slipping and any vibrations affecting the display.
AiM U Bolt Mount for Solo GPS Lap Timer - Option 2
The AiM U Bolt mount is suitable for a 0.5 to 1.2" bar, roll cage or railing. It is used to secure for Solo GPS lap timer to your preferred vehicle.
The AiM U Bolt mount is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
The bracket will securely mount the Solo, Solo 2 or Solo 2 DL to a roll bar, railing or tube. The U Bolt has a unique ball and socket system that provides a solid mounting and can cope with all Motorsport environments.
There are two U shaped junctions in the kit, which are 2.5cm and 3cm, to mount the mount to different sized bars.
AiM Suctin Cup Mount for Solo GPS Lap Timer - Option 3
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL. This bracket will securely mount the Solo GPS lap timer to any flat surface, such as your windscreen.
It has a 90mm locking and quick release suction cup, also a dual swivel joint, making viewing angle adjustment quick and easy.
Expand your System
There are some of the devices that can be added to the Solo 2 DL to boost your driving performance.
  • AiM Roll Bar Mount ( V Bracket)
  • 90mm (3.54inches) arm
  • Rollbar bracket
  • Clamp base with ball
  • Locknut
  • 4.5cm and 5.5cm tube clamp
  • Gasket
  • Screws & washers
  • AiM U Bolt Mount
  • 90 mm arm
  • Clamp base with ball 2.5cm & 3cm in diameter
  • U shaped junctions
  • Locknut
  • Screws & washers
  • AiM Suction Cup Mount
  • 90mm arm
  • Suction Cup
  • Locknut
  • Screws & washers
  • Whichever option is selected at check out
  • Option 1 - Roll Cage Mount
  • Option 2 - U Bolt Mount
  • Option 3 - Suction Cup Mount
Key Features:
Expand your System
  • Rollbar bracket
  • Locknut
  • Gasket
  • Screws & washers
  • AiM U Bolt Mount
  • 90 mm arm
  • Locknut
  • Screws & washers
  • 90mm arm
  • Suction Cup
  • Locknut
  • Screws & washers
