製品情報にスキップ
1 1
Husqvarna Plug & Play AiM Taipan Motocross ECU Kit
SKU: C-ECU-KIT-HUS
通常価格
£635.00
通常価格
セールスプライス
£635.00
注文すべてでカーボンニュートラルな配送
AiM Taipan ECU Plug & Play Kit For Husqvarna
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees the precision of 1/10 of degree: this means an accuracy within 0.8 use for turning the spark ON!
UC Bridge - Optional Extra
Tuner License :
Taipan ECU Connections
Below shows a functional diagram of products that can added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for Husqvarna
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for Husqvarna
Traction Control
Launch Control
The UC Bridge is the connection between the CAN bus of the ECCU and the USB port of your PC. It is available in 2 different licenses : User License : A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
Tuner License : With this license, the tuner can create different maps, configurations and strategies designed for the rider's bike. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
  • Waterproof: IP67
  • Weight: 260g
Video
