製品情報にスキップ
1 4
BMW S1000RR & S1000RR HP4 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-BMW
通常価格
£710.00
通常価格
セールスプライス
£710.00
注文すべてでカーボンニュートラルな配送
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the BMW this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide BMW ECU connection cable
This kit has been specifically designed for BMW bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your BMW ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following BMW bike models:
S1000RR - 2009-2014 S1000RR - From 2015
S1000RR HP4 - 2013-2014
The BMW ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the BMW plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM BMW Connection Cable
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
