GASGAS Plug & Play AiM Taipan Motocross ECU Kit for Linkpop
SKU: C-ECU-KIT-GG-XE1ECUHBSUCB0
- 通常価格
- £635.00
- 通常価格
- セールスプライス
- £635.00
- 単価
- あたり
+ VAT(英国のみ)
AiM Taipan ECU Plug & Play Kit For GASGAS Motocross Bikes
Taipan is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
Injection main alpha-n | Injection main speed-density |
Injection crank correction | Pre-injection |
Injection BAP Correction | Injection EWT Correction |
Injection IAT Correction | Injector Battery Correction |
Injector 2 | Ignition BAP Correction |
Ignition EWT Correction | Ignition IAT Correction |
Ignition Opening Transient Correction | Ignition Closing Transient Correction |
Launch Control | Injection Launch Control Main Table |
Ignition Launch Control Main Table | Quick Shift |
Traction Control |
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
![](https://cdn.shopify.com/s/files/1/0214/9392/files/tick-icon.png?v=1616588820)
UC Bridge - Optional Extra
Tuner License :
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections
AiM Taipan ECU Plug & Play Kit for GASGAS
- Two 0-5V analogue inputs sampled @ 1,000 Hz each, could be alternatively used as a switch to ground
- Second injector driver for high impedance saturated injectors (12Ω)
- One low side driver (1 A)
- Two CAN Bus, one for calibration purposes, one for expansions - (AiM handlebar switch, dataloggers, dash etc
- Three JST JWPF waterproof auxiliary connector
- Power consumption 150 mA
- Connectors: n. 1 JST 04T-JWPF-VSLE-S Connector
- n. 1 JST 08R-JWPF-VSLE-D Connector
- n. 1 JST 04R-JWPF-VSLE-S Connector
- n. 1 33 pin male Connector
- Body: PA6 + 30% glass fiber
- Dimensions: 89.4 x 75.4 x 29.3mm
- Weight: 260g
- Plug & Play ECU for GASGAS
Taipan is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.It provides the ultimate control in feeling, ignition, ignition phase, start maps, launch control, traction control with altitude and engine temperature corrections.
Traction Control |
For each map, the ECU has a dedicated traction control main table.Launch Control
For each map, the ECU has a dedicated launch control main table.High Technology 32-bit Core
![](https://cdn.shopify.com/s/files/1/0214/9392/files/COMPLETE_Cobra_Rebrand_Full_Image_List_Web-08.png?v=1633939190)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim-Cobra-ECU-UC-Bridge.png?v=1619782437)
Tuner License :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/COMPLETE_Cobra_Rebrand_Full_Image_List_Web-07.png?v=1633939233)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim-Cobra-Handlebar-Switch.gif?v=1617277273)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/COMPLETE_Cobra_Rebrand_Full_Image_List_Web-06.png?v=1633939270)
- Weight: 260g
Video
![GASGAS Plug & Play AiM Taipan Motocross ECU Kit for Linkpop - AimShop.com](http://www.aimshop.com/cdn/shop/products/COMPLETECobraRebrandFullImageListWeb-01notuner_1445x.png?v=1661260330)
- 選択を選択すると、ページ全体が更新されます。
