製品情報にスキップ
1 5
Ducati Panigale Solo 2 DL & SmartyCam 3 GP Track Day Camera Kit
SKU: SOLO2-K-DUC-1-SM-GPC-SM-CAM-GP-2
通常価格
£2,217.00
通常価格
セールスプライス
£2,217.00
注文すべてでカーボンニュートラルな配送
Ducati Panigale V4/V2 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The Ducati Panigale V4/V2 plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Automatic track recognition 712 male connector - 7 pin
Database with more than 4,000 tracks worldwide Ducati Panigale V4/V2 ECU connection cable
This ultimate track day kit has been specifically designed for Ducati Panigale V4/V2 bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following Ducati Panigale V4/V2 bike models:
Panigale V4 - From 2018 Panigale V2 - From 2020
Powerful Combination
The Ducati Panigale V4/V2 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the Ducati Panigale V4/V2 plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Ducati Panigale V4/V2 Plug & Play connection cable
  • Bracket
  • 1 washer
  • 1 rubber dowel
This ultimate track day kit has been specifically designed for Ducati Panigale V4/V2 bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance. SmartyCam 3 GP Features:
The Ducati Panigale V4/V2 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. With the added SmartyCam 3 GP camera you create an even more powerful system to help provide great videos that include all the technical information to help improve your performance. The SmartyCam 3 GP has four connections, one that is completely dedicated to the bullet cam, one for the ECU-MIC, one for a GPS Module connection and the final connector is for outputting the video footage for streaming. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
The GPS technology provides better reliability from the predictive lap timing function so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements.
SmartyCam 3 GP
The new SmartyCam 3 GP saves all your information to a supported micro-SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 automatically powers on and off with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, and lap & split times. T format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection. SmartyCam 3 GP features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps. With the built-in data logger experience enhanced RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 1 washer
  • 1 rubber dowel
