{"product_id":"liveu-solo-pro-hdmi-4-5g-live-video-streamer","title":"LiveU Solo PRO (HDMI のみ) 4\/5G ライブビデオストリーマー","description":"\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eThe UK’s Leading Live Streaming Device\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eTake your live streaming to the next level with LiveU Solo PRO – the professional-grade, portable video encoder trusted by motorsport creators, sports teams, videographers and broadcasters worldwide. \u003c\/p\u003e\n\u003cp\u003eWhether you’re transmitting SmartyCam 3 GP, GP Pro, or Dual footage straight to the pit, or streaming live to YouTube, Facebook, Instagram, Twitch and beyond, the LiveU Solo PRO delivers broadcast-quality 4K video with the reliability and freedom you need. \u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eWhy Choose the LiveU Solo PRO\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eGet rock-solid performance even in challenging network conditions. Enjoy up to 20Mbps streaming and optional HEVC\/H.265 encoding for maximum quality at minimum bandwidth. Available in HDMI or SDI\/HDMI versions, the LiveU Solo PRO ensures your live streams look as good as your vision.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDesigned for Creators\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eJoin thousands already using the Solo Creator Universe (SCU): \u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eIRL Streamers\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Go live anywhere, wire-free and stress-free. Add Solo Connect PRO, your creativity and a camera – then just go! \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eProduction Houses\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Stream live events from anywhere with IP-video over bonded 4G\/5G, no cables or venue networks required. \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eSports Teams\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Bring fans closer with easy-to-use, budget-friendly, broadcast-quality live streams. \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eEducational Institutions\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– From sports coverage to media training, the LiveU Solo PRO offers primetime results in a cost-effective package. \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eVideographers\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Trust award-winning tech with HEVC, 4K, LRT™, long battery life and lightweight mobility so you can focus on storytelling. \u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFuture-Proof Your Streaming\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eWith the next-gen Solo PRO encoder, you can stream to any leading social platform or website. Simply connect your camera or switcher, log in via the web-based Solo Portal, select your destination, and go live.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSolo Creator Universe Services \u0026amp; Accessories\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eLRT™ Bonding Technology\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Adaptive bitrate, bonded connections, and unmatched stability. Available monthly or annually. \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eSolo PRO Connect Kits\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Complete plug-and-play packages with modems, data plans, and LRT™ included (two or four modem options). \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eStream Tools\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Multi-destination streaming, stream fallback, and logo watermark for enhanced brand presence. \u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eSolo Belt Pack\u003c\/strong\u003e\u003cspan\u003e \u003c\/span\u003e– Comfortable, practical, and designed for streaming on-the-go. Includes Y-cables, HDMI pigtail cable and space for modems\/routers. \u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17813355593830__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eTrusted Worldwide\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe LiveU Solo PRO is used by global broadcasters and streaming partners including:  \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFacebook, YouTube, Twitch, Vimeo, Twitter\/X, Amazon Live, Dacast, Streann, Switchboard, Ustream, Grabyo, LinkedIn, Restream, Jstream\u003c\/strong\u003e. \u003c\/p\u003e\n\u003cp\u003eStream without limits – wherever the action takes you. \u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e","brand":"LiveU","offers":[{"title":"Default Title","offer_id":44433609162854,"sku":"LU-SOLO-PRO-HDMI","price":1355.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/LiveU_Solo_PRO_HDMI_1_0174a519-37c5-4c38-8010-3a8f10f37774.webp?v=1770392370","url":"https:\/\/www.aimshop.com\/ja-jp\/products\/liveu-solo-pro-hdmi-4-5g","provider":"AimShop.com","version":"1.0","type":"link"}
