{"product_id":"second-life-aim-formula-steering-wheel-4-320","title":"Second-Life Formula Steering Wheel 4 GT320","description":"\u003cstyle\u003e\n.product__info-wrapper .price-item--regular .money {\n display: flex;\n}\n\u003c\/style\u003e\n\u003cp style=\"text-align: center;\"\u003e\u003cmeta charset=\"utf-8\"\u003e\u003cstrong\u003e\u003cspan style=\"color: rgb(0, 170, 255);\"\u003e\u003cem\u003eThis Formula Steering Wheel 4 GT320 comes back to us as a trade-in, fully equipped and ready to take on its second life. The Steering Wheel is in full working order and has been meticulously checked by our technicians.\u003c\/em\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003ch3\u003e\u003cstrong\u003eAim Formula Steering Wheel GT320 with TFT Digital Display \u0026amp; Data Logger\u003c\/strong\u003e\u003c\/h3\u003e\n\u003cp\u003eThe all-new Aim Formula Steering Wheel 4 GT320 is our most advanced steering wheel to date. Get a closer look at our brand new design of display and functions.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe Formula Steering Wheel 4 is available in four unique sizes and incorporates an internal data logger with complete configuration.\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eRequires PDM08 or PDM32\u003c\/span\u003e\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e5\" TFT display\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eOver 2,000 ECU protocols\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e2 CAN available\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eAdditional CAN expansions\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eInternal data logger\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eDedicated RGB LED buttons\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e2 direct contact buttons\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e3 configurable rotary switches\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eRemovable handgrips\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eConfigurable keys: momentary, toggle, multi-status\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eOptional shift \u0026amp; clutch paddles\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eEasy configuration with Race Studio 3\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Formula_Steering_Wheel_4_GT320_main_image.png?v=1627460234\" alt=\"\"\u003e\u003c\/p\u003e\n\u003ch3\u003eAim Formula Steering Wheel GT320 with Internal Data Logger\u003c\/h3\u003e\n\u003cp\u003eThe new Aim Formula Steering Wheel GT320 is used for GT and closed cockpit cars. The internal data Logger is fully configurable and suitable for many different Motorsports. It has been designed to acquire and display data coming from the ECU with over 2,000 fully compatible ECU protocols. The New AiM Formula Steering Wheel GT320 is an excellent choice for compact cockpit installations where space is at a premium.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe Formula steering wheel 4 GT320 has ten push buttons and three rotary switches, all backlit with RGB LEDs.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe Formula Wheel has an internal data logger with complete configuration, removable grips, rotary switches and a long list of fully compatible ECU and CAN connectivity options.\u003c\/p\u003e\n\u003cp\u003eOur formula wheels come in a range of sizes. The difference between the Formula Steering Wheel 4 GT320 and the GT350 is the overall size of the wheel. The formula steering wheel GT350 is 10mm larger to meet every driver's requirements.\u003c\/p\u003e\n\u003cp\u003eThe Formula Steering Wheel 4 GT320 is also compatible with our PDM32 by talking through a CAN network. \u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eEasy Connection\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eConnecting the AiM Formula Steering Wheel GT320 to your ECU is simple. You can sample dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air\/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different ECUs.\u003c\/p\u003e\n\u003c!-- DIVIDER --\u003e\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eDisplay\u003c\/h3\u003e\n\u003cp\u003eThe Formula Steering Wheel 4 GT320 has a high contrast 5\" TFT display that is fully configurable and fully sunlight viewable. With the added ambient light sensor, the display stays straightforward to read. The wheel has eight visible shift lights and four-alarm RGB LEDs. The display is a high-quality solution for a formula wheel delivering clear, precise, and easy-to-read information to the driver.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eFlexible Alarms \u003c\/h3\u003e\n\u003cp\u003eThe AiM Formula Steering Wheel GT320 has eight configurable shift light RGB LEDs and four configurable alarm RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency. You can choose to have an accompanying text message and set the alarm priorities.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eWith integrated shift lights, you can choose from a host of advanced multi-coloured RGB shift light patterns that you can customise to suit your requirements and each unique gear when required.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eCAN Output\u003c\/h3\u003e\n\u003cp\u003eWith the CAN Output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eOptional Extras\u003c\/h3\u003e\n\u003cp\u003e\u003cstrong\u003eGPS Module\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eThe GPS Module connected via CAN to the AiM Formula Steering Wheel GT320 makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with start and finish line coordinates, you will have no problem when you're on track.\u003c\/p\u003e\n\u003cp\u003eAs soon as the steering wheel is turned on, the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start\/finish line coordinates to the MXG via a PC before going to the track using our Race Studio 3 software.\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eThe GPS Module is available 0.50m, 1.3m, 2m, 4m, or a roof version in 2m, 4m length cables.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eClutch Paddles\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e We offer a clutch paddle kit with the bottom left and right paddles or can be brought separately as either left or right, See the drop-down at the top of the page.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003eExpand your System\u003c\/h3\u003e\n\u003cp\u003eThere are a number of extra devices you can add to your system to help improve your driving performance, such as GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, RIO02, GS Dash, Memory Module.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\"\u003e\u003cimg style=\"width: 100%;\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Free_Download.png?v=1629297377\"\u003e\u003c\/a\u003e\u003c\/p\u003e\n\u003ch3\u003eConfigure \u0026amp; Analyse with Race Studio 3\u003c\/h3\u003e\n\u003ch4\u003eConfiguration\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.\u003c\/p\u003e\n\u003ch4\u003eAnalysis\u003c\/h4\u003e\n\u003cp\u003eWith Race Studio 3 you can also analyse all data recorded by the Formula Steering Wheel 3 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Academy\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg alt=\"Visit Aim Tech Support\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg alt=\"Download Race Studio Software\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003ch3\u003eAiM Formula Steering Wheel GT320\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eDisplay: 5\" TFT\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eResolution: 800 x 480 pixels\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eContrast: 800:1\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eBrightness: 800 cd\/m2 - 1,200 Lumen\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAmbient light sensor: Yes\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAlarm display icons: Yes, freely configurable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eShift lights: 8 configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eAlarm LEDs: 4 configurable RGB LEDs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eCAN connections: 3\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eECU connection: CAN\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eECU compatibility: 1,000+ industry leading ECUs\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eExpansion CAN connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, RIO02, GS Dash, Memory Module.\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eInternal memory: 4 GB\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePushbuttons: 10 pushbuttons + 3 rotary switches ( all with RGB backlights)\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eConnectors: 1 Deutsch Autosport 22 pin male connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eDimensions: 320 x 183.5 x 42.5mm\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWeight: 2,600g\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003ePower consumption: 500mA\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eWaterproof: IP65\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Formula_Steering_Wheel_GT320.png?v=1627459423\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Formula_Steering_Wheel_GT320_2.png?v=1627459558\"\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAiM Formula Steering Wheel GT320\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eFormula Steering Wheel 4 GT320\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e22 pin Male Deutsch Connector Harness\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable style=\"width: 100%;\" cellspacing=\"10\" cellpadding=\"10\" border=\"0\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_SW4_320_103.pdf?v=1634299135\" target=\"_blank\"\u003e \u003cspan data-mce-fragment=\"1\" class=\"AimProductDownloadsIcons\"\u003e\u003cimg data-mce-fragment=\"1\" alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg alt=\"\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/aim_SW4_320_103.pdf?v=1634299135\" target=\"_blank\"\u003eTechnical Sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"AiM Technologies Race Studio 3 Software Download\" href=\"https:\/\/www.aimtechnologies.com\/aim-software\/\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":42905879216230,"sku":"SN 8400409","price":1870.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/SW4320_920b6cc5-7108-482e-8c5e-cd4ea2443dcb.png?v=1779100426","url":"https:\/\/www.aimshop.com\/ja-jp\/products\/second-life-aim-formula-steering-wheel-4-320","provider":"AimShop.com","version":"1.0","type":"link"}
