製品情報にスキップ
1 2
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: YAM-1-PP-YAM-1-B
通常価格
£120.00
通常価格
セールスプライス
£120.00
注文すべてでカーボンニュートラルな配送
The AiM Yamaha motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Yamaha cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Yamaha Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Example data protocols
  • Specifically designed Yamaha Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Yamaha plug & play connection cable.
  • Yamaha plug & play connection cable
  • 1 bracket
  • 1 rubber dowel
  • 1 Allen screw with flay head M6
  • 1 rubber washer
  • 2 Allen screws with flat head M4 x 10
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged. The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike. Our brackets are supplied with all the necessary hardware required for fitting to your bike. Also, If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
  • 1 bracket
  • 1 rubber dowel
  • 1 rubber washer
