Yamaha YZF-R6 (2004-2005) Aim Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-YAM-4
- 通常価格
£710.00£852.00INC VAT - UK only
- 通常価格
- セールスプライス
- £710.00
- 単価
- あたり
Yamaha YZF-R6 (2004-2005) AiM Solo 2 DL Plug & Play Lap Timer Kit
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha YZF-R6 this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Yamaha YZF-R6 ECU connection cable |
This kit has been specifically designed for the Yamaha YZF-R6 bike. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha YZF-R6 ECU will give you all the engine performance information you need to help improve your driving performance.
Yamaha YZF-R6 (YEC included) - 2004-2005 | |
The Yamaha YZF-R6 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing of the Yamaha YZF-R6 plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Yamaha YZF-R6 Connection Cable
- Bracket
- 2 spacers
- 2 self-locking nuts M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers
- 2 Allen screws with rounded head M6 x 60mm
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha YZF-R6 this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for the Yamaha YZF-R6 bike. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha YZF-R6 ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The Yamaha YZF-R6 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. Add a SmartyCam HD/GP HD camera to create an even more powerful system to help provide you with great videos that include all the technical information to help improve your performance. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.Predictive Lap Timer
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
- 2 spacers
- 4 washers M6
- 2 washers
