Aim 37 Pin Connector and Pins MXS, MXP, MXG Female Deutsch Connector Motorcycle
SKU: P-37P-5...
- 通常価格
£125.00£150.00INC VAT - UK only
- 通常価格
- セールスプライス
- £125.00
- 単価
- あたり
The Aim 37 pin plug and pins are ideal if you need a replacement or to keep them as spares.
Suitable for MX Series | 37 pins, One plug |
Ideal for replacement or spares | |
The Aim Female Deutsch electrical connector is suitable with the Aim MX Series (MXS, MXG, MXP) dashes.
Use as a replacement part or as part of building a wiring loom.
- 37 Pins Female Deutsch Connector
- 37 Pins
- Plastic Pin Installation Tool
- Aim 37 pins connector kit
The Aim 37 pin plug and pins are ideal if you need a replacement or to keep them as spares.Key Features :
The Aim Female Deutsch electrical connector is suitable with the Aim MX Series (MXS, MXG, MXP) dashes.Use as a replacement part or as part of building a wiring loom.
- 37 Pins
