{"product_id":"aim-37-pin-deutsch-harness-with-2-thermocouples-mx-series","title":"Aim 37-Pin Deutsch Harness with 2 Thermocouples For MX Series","description":"\u003ch3\u003eAim 37 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2, MXm\u003c\/h3\u003e\n\u003cp\u003eThe Aim 37 pin Deutsch harness with two thermocouple connectors to connect K-Line type sensors.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for MXS, MXP, MXG MXL2 \u0026amp; MXm\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eDigital output\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e 37 pin harness\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eTwo thermocouple connectors\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003chr\u003e\n\u003ch3\u003e\u003cspan data-preserver-spaces=\"true\"\u003e37 pin Harness with Two Thermocouple Connectors for the MX Series\u003c\/span\u003e\u003c\/h3\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThe Aim 37 pins harness has been designed with two thermocouple connectors, this will enable you to connect two different thermocouple sensors to your device.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThermocouple sensors available are Exhaust Gas Temperature Sensor, Water\/Oil M5 Sensor, Water\/Oil M10 Sensor, and many more depending on the application.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThis harness can be used to replace a damaged harness or for a second vehicle installation when sharing a dash logger. \u003c\/span\u003e\u003c\/p\u003e\n\u003chr\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eThe Aim 37 pins Deutsch harness functions are listed below:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eAnalogue sensor channels (sensors) 1, 2, 3, 4\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eDigital wheel speed channel 1\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eOptical lap timing sensor output\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eCAN expansion\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003ePower+\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eGround-\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eCAN ECU connection\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eK-Line connection\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan data-preserver-spaces=\"true\"\u003ePlease Note:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan data-preserver-spaces=\"true\"\u003e If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan data-preserver-spaces=\"true\"\u003eAlso available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.\u003c\/span\u003e\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/MXL2_Expand_your_system.png?v=1622540800\" alt=\"Aim expansion example\" style=\"width: 100%;\"\u003e\u003c\/div\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your car or motorcycle for incrementing performance and data.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAim 37 Pin Deutsch Harness with 2 Thermocouples for MXS, MXP, MXG, MXL2 \u0026amp; MXm\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e37 pin Deutsch Female Flying Connector\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e4 pins Binder 719 Female connector - See table in Downloads Tab\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e5 pins Binder 712 Female Connector - See table in Downloads Tab\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e7 none ended cables - See table in Downloads Tab\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eTwo Thermocouple Connectors - See table in Downloads Tab\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003cdiv\u003e\u003cimg alt=\"Pinout for 37 Pin Deutsch Harness with 2 Thermocouples\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_37_Pin_Deutsch_Harness_with_2_Thermocouples_MXS_MXP_MXG_MXL2_Mxm_Technical_Pinout.png?v=1622561805\"\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim 37 Pin Deutsch Harness with 2 Thermocouples for MXS, MXP, MXG, MXL2 \u0026amp; MXm\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e37 pin Deutsch Harness with Two Thermocouple Connectors\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/V02.573.05_Cavo37pin_2TC_MX_MX1.2_rev3_eng.pdf?v=1622562212\" title=\"37 Pin Deutsch Harness with Two Thermocouple Connectors Technical Sheet\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"37 Pin Deutsch Harness with 2 Thermocouples technical sheet\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"Aim Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"Race Studio 3 Software Download\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/V02.573.05_Cavo37pin_2TC_MX_MX1.2_rev3_eng.pdf?v=1622562212\" title=\"37 Pin Deutsch Harness with Two Thermocouple Connectors Technical Sheet\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"Aim Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":39246277279846,"sku":"H37-DT-V02573050","price":375.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_37pinDeutchHarness2thermocoupleforMXseries_00.webp?v=1776337679","url":"https:\/\/www.aimshop.com\/ja\/products\/aim-37-pin-deutsch-harness-with-2-thermocouples-mx-series","provider":"AimShop.com","version":"1.0","type":"link"}
