Aim Absolute Boost Pressure Sensor M10 0-5 Bar Motorcycle
SKU: S-P-BO-...
- 通常価格
£190.00£228.00INC VAT - UK only
- 通常価格
- セールスプライス
- £190.00
- 単価
- あたり
The Aim M10 0-5 Bar absolute boost pressure sensor is suitable for manifold air pressure, reading pressures up to 5 bars.
M10 0-5 Bar | 4 pins 719 male binder |
The Aim Motorcycle M10 Absolute Boost Pressure Sensor, fitted with a male four pin black 719 binder plug connection, suits all Aim loggers and dash display/loggers.
Stock vehicle boost sensors are often slow to react and low resolution, offering limited logging and requiring the use of analysis software.
The Aim sensor is high resolution, fast responding and above all reliable, making it perfect for anyone serious about keeping their turbo engine in good health and tuning boost to its most efficient level. Suitable for manifold air pressure reading (MAP), read the depression to -1 bar about atmospheric pressure and absolute pressure up to 4 bars.
This sensor is also available in a Dash 3 3/8 0-5 Bar. Available in the accessories tab.
MXS / MXP / MXG / MXL (Strada and Pista) / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
- Supply: 8-16V
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: M10
- Aim bar pressure sensor M10 0-5 Bar
The Aim M10 0-5 Bar absolute boost pressure sensor is suitable for manifold air pressure, reading pressures up to 5 bars.Key Features :
The Aim Motorcycle M10 Absolute Boost Pressure Sensor, fitted with a male four pin black 719 binder plug connection, suits all Aim loggers and dash display/loggers. Stock vehicle boost sensors are often slow to react and low resolution, offering limited logging and requiring the use of analysis software. The Aim sensor is high resolution, fast responding and above all reliable, making it perfect for anyone serious about keeping their turbo engine in good health and tuning boost to its most efficient level. Suitable for manifold air pressure reading (MAP), read the depression to -1 bar about atmospheric pressure and absolute pressure up to 4 bars. This sensor is also available in a Dash 3 3/8 0-5 Bar. Available in the accessories tab.Connections
MXS / MXP / MXG / MXL (Strada and Pista) / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712 - 719 patch lead to connect these sensors.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: M10
