AiM Hall Speed Pick Up Sensor 712 Plug 2m Cable Motocross
SKU: S-S-H712-MX
- 通常価格
- £70.00
- 通常価格
- セールスプライス
- £70.00
- 単価
- あたり
Hall effect wheel speed sensor | 712 metal connector |
2m cable | M8 thread |
- 712 Metal Binder Connector
- Power Supply: 10-30 VDC
- Sensibility Distance: From 0.5 to 2,5mm
- Sensor Thread: M8
- Operating Temperature Range: -25 to 70°C
- 1 x Hall Effect Speed Sensor 712 Metal connector 2m Cable
AiM 712 Hall Speed Pick Up Sensor (2m cable). The output varies when it meets a magnetic field. The three-wire sensor produces a digital signal.Key Features :
AiM 712 Hall Speed Pick Up Sensor (2m cable). The output varies when it meets a magnetic field. The three-wire sensor produces a digital signal.The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. You will then be able to get a voltage. The Hall Effect Sensor is a non-contact device that needs a metallic trigger to pass in front of it. Again, a bracket will usually need to be fabricated to mount the sensor in a suitable position. Please ensure that the distance between the sensor and trigger is in a 0.5 – 2.0 mm (0.007-0.07 inches) range.
712 connection will suit EVO4 Data Loggers. ![]() |
- Sensor Thread: M8
- 選択を選択すると、ページ全体が更新されます。
