AiM Motorcycle Ecu Bridge With CAN/RS232 Communication Cable
SKU: SM-EB-CR
- 通常価格
- £250.00
- 通常価格
- セールスプライス
- £250.00
- 単価
- あたり
Product code: X90BRIDGE00 Motorcycle.
The Aim Motorcycle ECU Bridge CAN RS232. Connection is available in two variants, the OBDII connector for immediate plug & play connection to the OBDII port of Motorcycles with stock ECU's or CAN/RS232 connection for direct installation on aftermarket ECU's.
They are compatible with Aim MXL Dash, Aim G-Dash and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed on a display or on a SmartyCam video (if no recording is require.
ECU Bridge is to be used in when the Engine Control Unit transmits data by either OBDII, CAN or RS232.
Aim have developed hundreds of different protocols to make compatibility with virtually all ECU's possible, either stock and after market ECU's. ECU Bridge has to be properly configured with Race Studio 2 software to communicate with the different visors/cameras on one side and ECU's on the other side.
ECU Bridge Connection Example
RPM Bridge Connection Example
ECU with Aim Products
ECU Bridge is available in two variants:- With OBDII connector, for immediate plug&play connection to the OBDII port of cars with stock ECU's
- With CAN/RS232 connection, for direct installation on aftermarket ECU's.
RPM Bridge
RPM Bridge is to be used whenever the bike has got no ECU.
Technical Specification
- Configurable ECU interface
- CAN protocol for external modules (visors or SmartyCam HD)
- USB port for PC communication
- External power 8/18 V
- Coil signal 150-400 V
- Square wave signal 4-50 V
In The Box
ECU Bridge
- Aim Motorcycle ECU Bridge CAN RS232
- USB cable
ECU
Stock and Racing ECU's
You can find a list of ECU's on our support site here
- 選択を選択すると、ページ全体が更新されます。
