製品情報にスキップ
1 3
AiM RPM Car Coil Adapter For EVO4 - ARP04
SKU: EVO4-RPM-AD
通常価格
£75.00
通常価格
セールスプライス
£75.00
注文すべてでカーボンニュートラルな配送
This AiM adapter has been designed to supply RPM signals to an AiM EVO4 data logger on vehicles without an ECU.
Suitable for EVO4 logger For older vehicles
Filters & converts signal
This AiM adapter has been designed to supply RPM signals to an AiM EVO4 data logger on vehicles without an ECU. It connects to the coil and filters the signal, reducing noise and generating the correct square compatible with the EVO4 logger.
Connecting The RPM Coil Adapter
Connect the cable that ends with a five-pin binder 712 male connectors to RPM input of EVO4
Connect the black cable labelled GND to vehicle reference ground
Connect the red cable labelled 9-15 VDC to a switched 12V power supply
Connect the white cable labelled RPM 150-450V to the coil earth trigger
The yellow cable labelled DIGIT OUT is EVO4 digital output
  • Connecting the RPM Coil Adapter
  • Connect the cable that ends with a 5 pins Binder 712 male connector to RPM input of EVO4
  • Connect the black cable labelled GND to vehicle reference ground
  • Connect the red cable labelled 9-15VDC to a switched 12V power supply
  • Connect the white cable labelled RPM 150-450V to the coil earth trigger
  • The yellow cable labelled DIGIT OUT is EVO4 digital output
  • 1 x RPM Coil Adaptor for EVO4S
