AiM MyChron5 S 2T Ultimate Water Temperature Sensor Karting Kit
SKU: MY52T-TR-WT - S-T-M5-K - SM-UB-GP-R - SM-UB-GP - SM-CAM-W-GP-2 - SB12V2600P-AC - MY-EX - M5-BP - 3CVTRES001 - X90KSGPTP - X90KSBLTP - XB1SGPH22B12L200 - X08MYCEXP00 - X80MYC5TPB -
- 通常価格
- £1,880.00
- 通常価格
- セールスプライス
- £1,880.00
- 単価
- あたり
+ VAT(英国のみ)
MyChron5 S 2T Ultimate Karting Kit .
The AiM all new MyChron5 S 2T is our latest game changing data logger for Kart racing.
This kit comes with a MyChron5 S 2T and you choose which sensors you want to go with it and a MyChron5 Battery Blanking Plate. A SmartyCam GP HD 120° Bullet Camera with U Bolt Recording Box Mount & SmartyCam GP HD U Bolt Mount. A MyChron Expansion Box and a Super B 12v Battery.
SmartyCam GP HD Bullet Camera:
MyChron Expansion Box:
Choose the sensors you want for your kit: M10 Water Temperature Sensor, M5 Water Temperature Sensor.
In the following picture below you will appreciate the improvement we have made, passing from 10 to 25 data per seconds. The yellow dots show the new GPS data. |
Integrated GPSThe system takes advantage from an internal wide track database, in order to automatically understand which track you are at, where and how many are the magnetic strips: without any further sensor or configuration you will automatically get lap times, predictive lap times and split times. GPS data, acquired ten times per second, are of course recorded with other signals in the internal data logger, in order to offer the possibility of a deeper analysis of your performance.
Choose optimal layout for your data |
At the end of your session, you can recall the summary of your three best laps: lap time, max/min RPM, speed and temperature. For your best lap, you will also see splits and best theoretical time.
Five RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn them on/off. They also allow RPM monitoring in a glance. Even alarms are managed in a very flexible way: you choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off. |
Wireless data download with Wi-Fi connection
AiM SmartyCam Bullet GP HD 120° Camera
The Aim Mychron Expansion is a channel multiplier in help improve your MyChron5 S 2T performance, thanks to four additional additional analogue channels and a further connection for CAN bus.
Also included in the Kit a Super B 12v Battery |
The Super B battery is a lightweight and high performance lithium battery which has been designed for motorsports / Karting, for use in extreme environments. |
Lightweight, high-performance, safe and reliable lithium power battery especially developed for motorsport. The battery equals a lead-acid battery of 5 to 7AH provided the alternators maximum current doesn't exceed the battery maximum charge current of 10A. Suitable for 12v systems and for use in extreme environments.
MyChron5 S expansions and add-ons |
Our mission is to help educate you and enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional there is always something new to learn. |
MyChron5 S 2T
- Battery Charger with cable
- RPM Cable
- Temperature Sensors whichever you choose
SmartyCam GP HD Rev 2.2 Bullet Camera
- Connection cable 2m
- Software installation
- External power cable
Super B Battery
SmartyCam GP HD 2.1 + 2.2 U Bolt Mount for Recording Box
SmartyCam gp hd 2.1 + 2.2 U Bolt Mount
MyChron5 S 2T Blanking Plate
Integrated GPSThe system takes advantage from an internal wide track database, in order to automatically understand which track you are at, where and how many are the magnetic strips: without any further sensor or configuration you will automatically get lap times, predictive lap times and split times. GPS data, acquired ten times per second, are of course recorded with other signals in the internal data logger, in order to offer the possibility of a deeper analysis of your performance. |
At the end of your session, you can recall the summary of your three best laps: lap time, max/min RPM, speed and temperature. For your best lap, you will also see splits and best theoretical time. |
Lightweight, high-performance, safe and reliable lithium power battery especially developed for motorsport. The battery equals a lead-acid battery of 5 to 7AH provided the alternators maximum current doesn't exceed the battery maximum charge current of 10A. Suitable for 12v systems and for use in extreme environments. |
MyChron5 S 2T
- RPM Cable
Super B Battery
- 選択を選択すると、ページ全体が更新されます。
