Ducati Panigale V4/V2 Motorcycle Aim Solo 2 DL & SmartyCam 3 GP Plug & Play Track Day Kit
SKU: SOLO2-K-DUC-1-SM-GPC-SM-CAM-GP-2
- 通常価格
- £2,217.00
- 通常価格
- セールスプライス
- £2,217.00
- 単価
- あたり
A Powerful Track Day Combination
The Ducati Panigale V4/V2 plug & play kit, combined with the Solo 2 DL and SmartyCam 3 GP, gives you the ultimate track day experience.
The Ducati Panigale V4/V2 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike's functions or safety controls.
Plug & Play Compatibility
The plug & play cable currently fits the following Ducati Panigale V4/V2 bike models:
Panigale V4 - From 2018
Panigale V2 - From 2020
Why Choose The Solo 2 DL For Ducati Panigale V4/V2 Motorcycles
This ultimate track day kit has been specifically designed for Ducati Panigale V4/V2 bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
Solo 2 DL Key Features
The GPS technology provides better reliability from the predictive lap timing function so you can see in real time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see.
Solo 2 DL gives instant speed, timing splits, live data and predictive lap times.
The Solo 2 DL has a sharp, high-contrast display, helping drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements.
Precise Lap Times
Aim Solo 2 DL is the most precise GPS lap timer there is with the ability to show you your lap time live as you drive. Receiving data from two satellite constellations from anywhere on the globe by using GPS and Glonass also gives you a significant improvement in data speed and positioning precision.
This all adds up to your startup time being reduced to a matter of seconds, and lap times are accurate to a tolerance of two-hundredths of a second.
Solo 2 DL allows you to easily create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track, it can simply be added to the Solo 2 DL and PC database. Simply put, if there is no track already, the Solo 2 DL will create a new one for you.
With over 4,000 tracks pre-loaded from around the world, as soon as it's switched on, the Solo 2 DL identifies its position. Once you start to drive, it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past.
The Solo 2 DL has integrated Wi-Fi, so if you want to review your data in more depth, simply transfer your data securely and quickly onto a laptop or computer up to 50m away without connectors and cables. You can then import the data into the free Race Studio 3 software.
Why Choose The SmartyCam 3 GP For Ducati Panigale V4/V2 Motorcycles
The new SmartyCam 3 GP saves all your information to a supported micro-SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the SmartyCam 3 GP automatically powers on and off with your engine – and will start/stop recording for you.
Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, and lap & split times. The format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
SmartyCam 3 GP features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, like your pit crew, at 30 or 60fps.
The built-in data logger helps you monitor RPM, throttle, engaged gears, acceleration, temperatures, and pressures, including a tri-axis accelerometer measuring 16G.
SmartyCam 3 GP Key Features
Automatic Start/Stop
With Race Studio 3, you can also analyse all data recorded by Solo 2 DL and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Ducati Panigale V4/V2 Aim Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
- Display: Graphical
- Backlight: 8 configurable RGB colours
- GPS: 10 Hz
- External power: 12 V
- Connectors: 1 socket (binder) 712, 5 pins, 1 socket (binder) 712, 8 pins
- Memory: 4 GB
- Weight: 240g, battery included
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
Below is the pinout drawing for the Ducati Panigale V4/V2 plug & Play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Ducati Panigale V4/V2 Plug & Play connection cable
- Bracket
- 1 washer
- 1 rubber dowel
Precise Lap Times
- GPS: 10 Hz
- Memory: 4 GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- Bracket
- 1 washer
- 1 rubber dowel
- 選択を選択すると、ページ全体が更新されます。
