{"product_id":"link-boost-control-solenoid-3-port","title":"Link Boost Control Solenoid 3 Port","description":"\u003cp\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Link_Banner_Description.png?v=1616071775\" style=\"width: 100%;\"\u003e\u003c\/p\u003e\n\u003ch3\u003eLink Boost Control Solenoid 3 Port\u003c\/h3\u003e\n\u003cp\u003eNeed more boost then this 3 port boost control solenoid will help you do it. \u003cbr\u003e\u003cbr\u003e3 port boost control solenoids are the go-to for the majority of boost control applications, they allow for precise control of boost and boost levels can be raised to around 2-3 times the spring pressure of the wastegate.\u003cbr\u003e\u003cbr\u003eFor higher boost applications consider our 4-Port boost control solenoid.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3 data-mce-fragment=\"1\"\u003eFeatures\u003c\/h3\u003e\n\u003cp\u003eCompatible with all Link ECU’s\u003cbr data-mce-fragment=\"1\"\u003eCan be used with single or multiple wastegates (Using T junction)\u003cbr data-mce-fragment=\"1\"\u003eCompatible with internal or external wastegates\u003cbr data-mce-fragment=\"1\"\u003eFast and consistent response times\u003cbr data-mce-fragment=\"1\"\u003eHigh shifting forces\u003cbr data-mce-fragment=\"1\"\u003eMAC 35 series – Rugged, reliable and long operational life\u003cbr data-mce-fragment=\"1\"\u003eShort stroke, high flow\u003cbr data-mce-fragment=\"1\"\u003eBalanced poppet, immune to variations of pressure\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eWe recommend starting with a PWM frequency of 20Hz for this Boost control solenoid. A detailed description of setting up boost control can be found in the help file in the PC Link software which is available in the download tab.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch5\u003eTechnical \u003c\/h5\u003e\n\u003cp\u003e \u003cspan data-mce-fragment=\"1\"\u003eMAC 35 series\u003c\/span\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cspan data-mce-fragment=\"1\"\u003e120 PSI max\u003c\/span\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cspan data-mce-fragment=\"1\"\u003e1\/8” BSPPL\u003c\/span\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cspan data-mce-fragment=\"1\"\u003e12 VDC (5.4W) \u003c\/span\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cspan data-mce-fragment=\"1\"\u003e18” (45cm) coil leads\u003c\/span\u003e\u003cbr data-mce-fragment=\"1\"\u003e\u003cspan data-mce-fragment=\"1\"\u003eIncludes 3 x 1\/8” BSP hose tail fittings for easy connection\u003c\/span\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eLink Boost Control Solenoid 3 Port\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e3 Port Boost Control\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e3 x 1\/8\" BSP hose tail fittings for easy connection\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cbr\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PC_LINK_Downloads.png?v=1616072312\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimshop.com\/pages\/pc-link-downloads\" title=\"PC Link Downloads\" target=\"_blank\"\u003e \u003cspan style=\"color: #088cf7;\"\u003ePC Link Downloads\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Link","offers":[{"title":"Default Title","offer_id":39295498584166,"sku":"3BCS","price":93.5,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/products\/LinkBoostControlSolenoid3Port.png?v=1618237873","url":"https:\/\/www.aimshop.com\/ja\/products\/link-boost-control-solenoid-3-port","provider":"AimShop.com","version":"1.0","type":"link"}
