제품 정보로 건너뛰기
1 4
AiM 712-712 Male to Male 5 Pin CAN Patch Lead Motorcycle
SKU: P-712-712-MM-5-5-V02554790
정가
£40.00
정가
세일 가격
£40.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM 712-712 male to male five-pin patch lead has metal screw-on connectors.
712-712 patch lead 5 pin male to male
High-quality connectors Various lengths available
Our AiM CAN cable connects hardware components in the AiM CAN system (Controller Area Network). You would use these cables to connect Channel Expansion Hubs, ECU Bridge, Lambda Controller, GPS module, and any other peripheral hardware to a Data Hub. Or from the Data Hub to the dash/logger harness. These cables use the metal Binder 712 screw-on connectors with 5-pins in the housing. They are available in various lengths.
AiM CAN cables link modules or hardware on the AiM-specific CAN system (Controller Area Network). These cables transfer data or power from one AiM component to another. It should not be confused with the CAN system in your vehicle's factory wiring. They are separate CAN systems. Only in specific cases will an AiM CAN component interface with a vehicle CAN component, such as linking vehicle ECU data to a data logger.
  • 712-712 5 pins Male to Male CAN Patch Lead
  • Available in a variety of lengths:
  • 50cm
  • 100cm
  • 150cm
  • 200cm
  • 1 x 712-712 Male to Male 5 Pin CAN Patch Lead
  • 50cm
  • 100cm
  • 150cm
  • 200cm
