AiM Taipan Solo 2 DL Extension Cable
SKU: C-SOLO-P
- 정가
- £45.00
- 정가
- 세일 가격
- £45.00
- 단가
- 당
+ VAT(영국만 해당)
The AiM Taipan Solo 2 DL extension cable has been specifically designed to connect the Taipan ECU and the Solo 2 DL.
Solo 2 DL extension cable | 50cm length cable |
AiM Taipan Accessories
The AiM CAN Solo 2 DL extension cable has been manufactured to connect the Solo 2 DL to the AiM Taipan ECU.
The patch lead has a 7 pin male binder connector that connects to the Solo 2 DL and the JST connector connects to the Taipan ECU and is available in a 50cm long cable.
UC Bridge - Optional Extra
User License:
A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
The UC Bridge is required for two functions:
Tuner License:
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections - Optional Extra
- Solo 2 DL Extension Cable
- Length: 50cm
- 712 male binder connector - Cable 150mm
- 4P Male JST Connector
- 04T-JWPF-VSLE-S
- PIN SWPT-001T-P025 - Cable 350mm
- 4P Female JST connector
- 04R-JWPF-VSLE-S
- PIN-SWPR-001T-P025
- Black - GND
- White - CAN EXP H
- Blue - CAN EXP L
- Red - 12V
- AiM Solo 2 DL Extension Cable 50cm
The AiM Taipan Solo 2 DL extension cable has been specifically designed to connect the Taipan ECU and the Solo 2 DL.Key Features :
The AiM CAN Solo 2 DL extension cable has been manufactured to connect the Solo 2 DL to the AiM Taipan ECU.The patch lead has a 7 pin male binder connector that connects to the Solo 2 DL and the JST connector connects to the Taipan ECU and is available in a 50cm long cable.
User License:
Tuner License:
- Length: 50cm
- 04T-JWPF-VSLE-S
- 04R-JWPF-VSLE-S
- Black - GND
- White - CAN EXP H
- Blue - CAN EXP L
- Red - 12V
Video
