제품 정보로 건너뛰기
1 1
AiM ECU Bridge for Ferrari F430 Challenger GT3
SKU: SM-EB-FER
정가
£340.00
정가
세일 가격
£340.00
+ VAT(영국만 해당)
모든 배송은 탄소 중립적입니다.
Powered by Shopify Planet
The Aim ECU Bridge for Ferrari F430 Challenger GT3 is the connector for immediate plug & play connection to the OBDII port of cars with stock ECUs or CAN/RS232 connection for direct installation on aftermarket ECUs.
They are compatible with Aim MXL Dash, Aim G-Dash and Aim Formula steering wheels, and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
Aim ECU Bridge
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed on a display or on a SmartyCam video (if no recording is required)
They are compatible with MXL Dash, G-Dash and Formula/GT steering wheels, and of course with the SmartyCam and SmartyCamGP.
ECU Bridge is to be used when the Engine Control Unit transmits data by either OBDII, CAN or RS232.
Aim has developed hundreds of different protocols to make compatibility with virtually all ECUs possible, either stock or aftermarket ecus. ECU Bridge has to be properly configured with Race Studio 2 software to communicate with the different visors/cameras on one side and ecus on the other side.
ECU Bridge Connection Example
RPM Bridge Connection Example
Aim RPM Bridge Connection Example
ECU with Aim Products
ECU Bridge is available in two variants:
  • With an OBDII connector, for immediate plug&play connection to the OBDII port of cars with stock ECU's
  • With CAN/RS232 connection, for direct installation on aftermarket ECU's.
Aim CAN - RS232 connection
RPM Bridge
RPM Bridge is to be used whenever the car has got no ECU (i.e. classic cars).
In this case, RPM data can be obtained with connection to the coil or by reading a square wave signal generated by the ignition system.
Aim ECU Bridge CAN  K-LINE
  • Configurable ECU interface
  • CAN protocol for external modules (visors or SmartyCam HD)
  • USB port for PC communication
  • External power 8/18 V
  • Coil signal 150-400 V
  • The square wave signal 4-50 V
    ECU Bridge  ECU Bridge with connection cable (CAN/RS232 or CAN/K Line) USB cable  RPM Bridge  RPM Bridge with connection cable (loose wires) USB cable
    ECU Bridge
    • ECU Bridge with connection cable (CAN/RS232 or CAN/K Line)
    • USB cable
      RPM Bridge
      • RPM Bridge with connection cable (loose wires)
      • USB cable
        Stock and Racing ECU's
        You can find a list of ECU's on our support site here
        Aim ECU Bridge
        ECU Bridge
        RPM Bridge
        Technical Specification
          In The Box
          ECU Bridge
          • USB cable
            RPM Bridge
            • USB cable
              ECU
