AiM Four-Way Data Hub CAN Connection Multiplier Kart
SKU: CAN-M-40
- 정가
- £65.00
- 정가
- 세일 가격
- £65.00
- 단가
- 당
+ VAT(영국만 해당)
The AiM four-way Data Hub provides a CAN channel and works as an interface between our AiM loggers and sensors.
Five pins 712 male Binder | Four-way hub |
CAN connection | Build a network |
The compact Data Hub provides four additional CAN channels and works as an interface between the AiM logger and its peripheral devices and accessories. Such as the LCU Lambda Controller, Memory key and SmartyCams.
The four-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
You can use the four-way Data Hub with our Mychron's and loggers powered by the vehicles 12V onboard battery supply.
Two-way data hub with external power leads
Two-way data hub
- Dimensions: 123 x 30 x 23.5mm
- CAN cable length: 40/150cm
- Weight: 97g
- x 1 Four-way Data Hub
The AiM four-way Data Hub provides a CAN channel and works as an interface between our AiM loggers and sensors.Key Features :
The compact Data Hub provides four additional CAN channels and works as an interface between the AiM logger and its peripheral devices and accessories. Such as the LCU Lambda Controller, Memory key and SmartyCams.Using many devices can result in excessive wiring. Thanks to the data hub, it can eliminate all unnecessary wiring.
Two-way data hub
- Weight: 97g
