제품 정보로 건너뛰기
1 2
AiM Infrared Tyre Temperature Sensor Kart
SKU: S-T-IR-K
정가
£95.00
정가
세일 가격
£95.00
+ VAT(영국만 해당)
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Powered by Shopify Planet
The AiM Infrared (IR) tyre temperature sensors have four pins black 719 binder plug connections to fit all AiM loggers and dash display/loggers.
IR Temperature sensor 719 binder connection
Our infrared tyre temperature sensor has been specifically designed to measure the surface temperature of tyres, providing information for chassis tuning, tyre exploitation and driver behaviour.
Ensure to place the sensor far from strong heat sources like the exhaust pipe and electromagnetic interference.
Connection
MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm MyChron etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719-719 patch lead, which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect these sensors.
  • Output Signal: 0-5V
  • Field of measure: 35°
  • Working range: -20/120°C
  • Sensor electrical range: 820 Mv/-20°C, 3230Mv/120°C
  • Sensor dimensions: 26.6 x 17.2mm
  • IP rating: IP65
  • Sensor cable length: 250mm
  • x 1 IR Tyre Temperature Sensor
Connection
  • IP rating: IP65
