Aim IR Pick Up 719 Plug 90cm
SKU: S-IR-719-9
- 정가
£80.00£96.00INC VAT - UK only
- 정가
- 세일 가격
- £80.00
- 단가
- 당
Aim IR Optical Lap Receiver 719 Plug
The Aim Infrared Receiver is a spare or replacement Receiver that is installed in your vehicle and receives the lap signal from the infrared transmitter.
Spare / Replacement Receiver | 4 pin 719 connector |
The Aim Infrared Receiver sometimes referred to as an Optical Lap Receiver is installed in your vehicle and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal.
It is also available with a 4 pin metal plug connector.
The infrared receiver is available with a 90cm lead, it is also available with 300cm lead for cars, although there is nothing stopping you from using the lead that best suits your requirements.
Installation
The Infrared receiver should be fixed to your vehicle by fixing through the fixing hole at the top of the receiver. When fixing the receiver be sure that the eye is pointing to the side of the track where the receiver has been installed.
Analyse with Race Studio 3
With Race Studio 3, you can also analyse all data recorded and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Aim IR Optical Lap Receiver 719 Plug 90cm
- Binder connection Pinout:
- 1 - n.c
- 2 - GND
- 3 - V battery (7-15 VDC)
- 4 - Optical Lap Signal
- IR Optical Lap Receiver 719 Plug 90cm
The Aim Infrared Receiver is a spare or replacement Receiver that is installed in your vehicle and receives the lap signal from the infrared transmitter.Key Features :
The Aim Infrared Receiver sometimes referred to as an Optical Lap Receiver is installed in your vehicle and receives lap signals from the infrared transmitter positioned at the side of the track. It just needs to be pointed to the side of the track where the transmitter is installed to be able to read the signal. It is also available with a 4 pin metal plug connector. The infrared receiver is available with a 90cm lead, it is also available with 300cm lead for cars, although there is nothing stopping you from using the lead that best suits your requirements. Please Note: The IR Optical Lap Transmitter Beacon is available to purchase in our accessories tab.Installation
With Race Studio 3, you can also analyse all data recorded and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- 1 - n.c
- 2 - GND
