제품 정보로 건너뛰기
1 1
Motorcycle Potentiometer Replacement Rose End Fitting
SKU: CASUS-POT-END-RJ-MC
정가
£8.50
정가
세일 가격
£8.50
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Replacement rose end joint fitting for the suspension potentiometer.
Key Features:
Replacement rose end fitting Spare or replacement parts
Aim Potentiometer Replacement Rose End Fitting
The motorcycle potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
  • Replacement Potentiometer Rose End Fitting
  • 1 x Rose End Fitting Potentiometer Replacement Fitting
Key Features:
The motorcycle potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor. Use as a replacement or spare part.
