AiM Oil/Water Thermocouple Temperature Sensor M5 Type K Motorcycle
SKU: S-T-M5-M-MC
- 정가
- £70.00
- 정가
- 세일 가격
- £70.00
- 단가
- 당
AiM Oil/Water Thermocouple Temperature Sensor M5 K Type
The AiM oil/water thermocouple temperature sensor with M5 thread allows you to measure oil/water temperature by placing the thermocouple in the cooling system.
Measure oil/water temperature | Thermocouple male fitting |
Wide temperature range | 2 pins |
It can measure the oil/water temperature by being placed in the cooling system. When fitting the sensor ensure it is far away from heat and electromagnetic interference sources like the RPM cable or lap receiver cables.
Temperature range of 0-150°C
Sensor cable length 25cm
- Temperature working range: 0-150°C
- Cable sensor length: 25cm
- Cable Type: Compensated
- Two pins male thermocouple connection
- K Type thermocouple
- AiM Thermocouple M5 Oil/Water Temperature Sensor
The AiM oil/water thermocouple temperature sensor with M5 thread allows you to measure oil/water temperature by placing the thermocouple in the cooling system.Key Features :
The AiM K Type thermocouple temperature sensor is fitted with a two pins male thermocouple connection.It can measure the oil/water temperature by being placed in the cooling system. When fitting the sensor ensure it is far away from heat and electromagnetic interference sources like the RPM cable or lap receiver cables.
To use the sensors with EVO4 and EVO4S data loggers, you will need a TC yellow 712 4 pin patch lead (metal binder plug) or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger, you will need a TC yellow 712 3 pin patch lead (metal binder plug).MXS, MXG, MXP, MXL2 and EVO5 will require a TC - TC yellow patch lead. To connect the thermocouples to these Aim dash/loggers, you need to use the dedicated harness supplied with your device.
