제품 정보로 건너뛰기
1 2
Aim SmartyCam GP HD U Bolt Mount For Recording Box Offroad
SKU: SM-UB-GP-R-MX
정가
£80.00
£96.00
INC VAT - UK only
정가
세일 가격
£80.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
정가
£80.00
£96.00
INC VAT - UK only
정가
세일 가격
£80.00
AiM SmartyCam GP HD U Bolt Mount For Recording Box 2.1 & 2.2
The SmartyCam GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Suitable for 0.5 to 1.2" bar, roll cage, railing For SmartyCam GP HD 2.1 & 2.2
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.
The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2".
  • For use with SmartyCam GP HD 2.1 & 2.2
  • Height: 90mm (3.54inches)
  • U bolt
  • 90mm arm
  • Clamp base with ball
  • Mounting bracket
  • Locknuts
  • Washers and screws
Technical sheet Race Studio 3
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches. The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport. The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
  • U bolt
  • 90mm arm
  • Mounting bracket
  • Locknuts
