제품 정보로 건너뛰기
1 2
AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2
SKU: SM-VB-GP
정가
£80.00
정가
세일 가격
£80.00
+ VAT(영국만 해당)
Shopify Planet을 통한 탄소 중립 배송
모든 배송은 탄소 중립적입니다.
Powered by Shopify Planet
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Clamp to a wide range of diameter tubing For SmartyCam GP HD 2.1 & 2.2
Roll Cage Mount
  • For use with SmartyCam GP HD 2.1 & 2.2
  • Handlebar bracket
  • 60mm arm
  • Ball head
  • Bullet cam bracket
Technical sheet Race Studio 3
Roll Cage Mount
  • Handlebar bracket
  • 60mm arm
  • Ball head
